Manual Transmission Fluid - Question
Old Jul 17, 2016 | 02:32 PM
awestrella14's Avatar
awestrella14
Exclamation Manual Transmission Fluid - Question
So I had to have my transmission replaced at Infinity due to the Synchro not working properly. I have had the transmission now for (+/-) 15K miles. I am going to be changing the transmission fluid and was wondering what everyone recommends? Is OEM the best options to keep these transmissions running smoothly or is changing the viscosity something to consider?
Any advise is greatly appreciated!
Old Jul 17, 2016 | 02:58 PM
Thirty_Seven's Avatar
Thirty_Seven
Don't change the viscosity unless you live in an extremely cold or extremely hot climate. Even then it's not the best idea. Use OEM fluid or Redline MT-85 (my personal favorite). You shouldn't need to change it out at 15k miles anyway but you can go for it if you want.
Old Jul 17, 2016 | 09:09 PM
HoldmyMouse's Avatar
HoldmyMouse
I personally would suggest you stick with OEM in the mean time mainly because you are still within your warranty period.
Old Jul 19, 2016 | 06:49 AM
Pgwn-g37's Avatar
Pgwn-g37
^^ I agree with Mouse, keep the warrenty going.
I however, put in AMSOIL and liked it so far but only put on about 500 miles and then got deployed....
Side note, and might be stupid question as well, but how did you know your syncros were going? Mine are either going or I need to upgrade the CSC to a HD because my upgraded clutch might be putting out too much heat. OEM fluid would get that spongy feeling after 30 min, now I got RBF +600 and it was holding like a champ for 1000 miles....now when I shift seems like it misses or doesn't want to go into gear? More than likely my CSC though.
Old Jul 19, 2016 | 09:42 AM
Thirty_Seven
Sounds more like a CSC to me as well. Worn synchros will usually grind when you shift.
And OP, I forgot you were within warranty period as well, so I'd vote OEM rather than Redline like I said earlier.
Old Jul 19, 2016 | 08:21 PM
saywat?'s Avatar
saywat?
why the hell would u change it at only 15k? u bored?
Old Jul 22, 2016 | 11:24 AM
Pgwn-g37's Avatar
Pgwn-g37
But you could still 'shift'? Because, I want to say it would not go into gear and I didn't force it into gear, once I felt my hand 'vibrate'(would that be the same as grinding?) I would just cycle the clutch and it would go in.
Old Jul 22, 2016 | 12:44 PM
Kris9884's Avatar
Kris9884
So is this a break in flush or something? Why are you changing it so soon?
Old Jul 22, 2016 | 02:10 PM
saywat?'s Avatar
saywat?
im wondering if op is the cause of the initial trans issue that was replaced
Old Jul 22, 2016 | 04:01 PM
HoldmyMouse
It's good to change out the fluid after the break in period.
Calidoso
Dec 20, 2016 07:47 PM
PNW_IPL
Aug 11, 2016 11:49 PM
pureoptic
May 1, 2016 03:53 AM
Mr.Moto
Apr 26, 2016 08:12 PM
botlfed98
Apr 22, 2016 10:50 PM
