Z1 oil cooler install issues AWD
Old Jun 13, 2016 | 11:06 PM
Upscale Speed's Avatar
Upscale Speed
My installer is having a difficult time installing my oil cooler. I have an X sedan and got the kit with the thermostatic plate. In being told he can get one like connected but not the second. I think he may be routing the lines wrong. Can anyone with an X give me some tips to pass along to him?
Old Jun 14, 2016 | 11:26 AM
SonicVQ's Avatar
SonicVQ
I don't think that oil cooler fits on the AWD models as the install instructions don't mention G37X: https://www.z1motorsports.com/upload...llManualJD.pdf
The AWD G37's oil filter has a factory 90* adapter for the oil filter. This means the filter points to the FRONT of the car. The 370z & G37S oil filter is mounted directly on the side of the engine block and point to the front passenger tire.
All Wheel drive:
2 Wheel Drive:
Contact Z1 to verify.
Good luck!
Old Jun 14, 2016 | 01:08 PM
Upscale Speed
Shoot will call Z1 now.
Old Jun 14, 2016 | 02:07 PM
ANMVQ's Avatar
ANMVQ
I had the same issue with mine , the lines route is completly different. My installed called Z and they told him it was only tested on a RWD car. mine run behind the passanger side wheel splash shield and you have to clock the plate to like 7 oclock. I think it instructions have it at like 3 :/
Old Jun 14, 2016 | 05:29 PM
Upscale Speed
Did you run both lines through the splash shield?
Old Jun 15, 2016 | 08:15 AM
ANMVQ's Avatar
ANMVQ
Yes, we did, they both go through the passenger side sheild at the bottom then up and over the top, its a two part piece.
Old Jun 15, 2016 | 08:45 AM
Upscale Speed
He got it done last night. Thanks Mike you're input was the key. Install successful!!! Now onto the nitrous kit. Probably doing some vinyl wrapping next week, then following week will be nitrous. Can't wait!
Old Jun 15, 2016 | 08:57 AM
ANMVQ's Avatar
ANMVQ
Nice Shaun glad it worked out man.
NOS Eh, U had a 200 shot on a built 70 Camaro I had, thing was STUPID!! LOL My license plate was ULOST AHAH
Old Jun 15, 2016 | 10:26 AM
Upscale Speed
haha. I'll start with a 100 shot, I got the Maximizer 4 Progressive controller and Visconti says he can write a tune MAP for nitorus for me. It should be blast to take a new Camaro SS at the strip.
Old Jun 16, 2016 | 07:29 AM
ANMVQ's Avatar
ANMVQ
Where'd you get the stuff and who's installing it? I really liked it when I had it but I the thing I see being and issue is ( I KNOW) but on the street to have fun how would we change maps, the car has to be stopped, and I wouldn't thing you could drive 100% on that map and it would only be for NOS?
Old Jun 16, 2016 | 10:43 AM
m3clubracer's Avatar
m3clubracer
Pictures/writeup?
Old Jun 16, 2016 | 03:54 PM
Upscale Speed
See pics of my install. It turned out fine after Mike's advice.
Attached Thumbnails Z1 oil cooler install issues AWD-img_2075.jpg   Z1 oil cooler install issues AWD-img_2080.jpg   Z1 oil cooler install issues AWD-img_2084.jpg   Z1 oil cooler install issues AWD-img_2085.jpg
Old Jun 17, 2016 | 08:02 AM
ANMVQ's Avatar
ANMVQ
^^ Thanx LOVE The Z1 drain plug, You'll have to keep an eye on the fittings at the plate mine seap, almost all the time. I check them every oil change. But again I bet this is just "my" considering I can't get anything done right :/. LOL
Old Jul 25, 2016 | 04:25 PM
Mattlorentzoe's Avatar
Mattlorentzoe
Thanks for the pictures. I am starting the install now! Any other pointers for me? How's it holding up?
Old Jul 25, 2016 | 04:30 PM
Mattlorentzoe
They seap?????????? Like how much?
