Help car pulses when brakes applied
Old Jun 3, 2016 | 02:23 PM
G10's Avatar
G10
Hi Guys -
My car pulses when brakes applied and I feel the pulses on my break paddle a lot. Any thought how and whats causing this issue ?
Old Jun 3, 2016 | 02:27 PM
slartibartfast's Avatar
slartibartfast
Brake pedal. You've been *****-footing around. Find a lonely spot on a freeway and brake HARD down to about 10 mph, then return to speed limit. Lather, rinse, repeat. After six of those, you'll have scrubbed off the brake pad material that's transferred to the rotor.
If that doesn't fix the pulsing, have the rotors skimmed.
Old Jun 3, 2016 | 03:01 PM
Kris9884's Avatar
Kris9884
So what's causing this if its not warped rotors? What's wrong with the pedal?
Old Jun 3, 2016 | 03:24 PM
G10's Avatar
G10
Thanks slartibartfast -
Would this apply to drilled and slotted Rotors ?
Old Jun 3, 2016 | 04:27 PM
Yes, you're just trying to remove the high/uneven pad deposits.
Old Jun 3, 2016 | 11:27 PM
bikezilla's Avatar
bikezilla
Poor braking technique causes this?
That is to ask,
can the deposits be caused by gentle braking?
Old Jun 3, 2016 | 11:32 PM
slartibartfast
Warping of rotors is very uncommon. Yes, brake pad material can preferentially deposit on the the rotor surface. That and local overheating creating cementite which is harder than the iron of the rotor.
http://www.stoptech.com/technical-su...nd-other-myths
Old Jun 3, 2016 | 11:54 PM
bikezilla's Avatar
bikezilla
-Warped- Brake Disc and Other Myths
Cementite. Ha, haven't heard that term since 3rd semester materials. That brings back memories. (Mostly hangovers)
Thanks for the link. Good read.
Old Jun 4, 2016 | 11:40 AM
Kris9884's Avatar
Kris9884
Ah, I learned some good stuff in there..
thatgforce23
May 22, 2019 09:28 PM
jonpak
Buying & Leasing
Aug 29, 2016 10:36 AM
Ihtbealexxx
Jun 13, 2016 12:54 PM
larryw
Jun 2, 2016 06:43 PM
Louiegee97
May 29, 2016 05:28 AM
