Help RE: G25 Issues
Old Jun 2, 2016 | 01:27 PM
Zenzae's Avatar
Zenzae
RE: G25 Issues
Hello Folks,
I have been lurking around these forums for the last couple week. There's some great information here so I decided to join.
My pops has a G25 but the engine is smoking like crazy. The mechanic said it was valve seal, but replaced the seals without checking cylinder compression.
Unfortunately, he reinstalled the heads and then tested the car and it still smokes. I was wondering what would be necessary to change from the VQ25hvr to a VQ37hvr, because these engines seem to be more readily available.
And if not do you have any recommendations apart from an overhaul kit from Infiniti?
Thanks,
Zenzae
Old Jun 2, 2016 | 02:54 PM
slartibartfast's Avatar
slartibartfast
What color is the smoke? Valve seals smoke upon start up and closed throttle deceleration and tends towards light gray. Leaking coolant gaskets cause steam to come out the exhaust and will cause overheating. Bad ring(s) will cause dark smoke when accelerating.
Old Jun 17, 2016 | 11:52 AM
Zenzae's Avatar
Zenzae
Thanks Slartibart,
We changed the valve seals, the head gasket and vacuum hose and the car is running like a champ again. Entire process cost $850.
Zen
Old Jun 17, 2016 | 12:50 PM
slartibartfast
Head gaskets FTW
Brian Londry
20
Apr 17, 2022 11:49 PM
F23jeff
General Tech Questions
Aug 16, 2016 04:48 PM
slartibartfast
Site Feedback & Suggestions
58
May 28, 2016 08:11 PM
JohnsG37x
Apr 15, 2016 03:45 PM
bonstubon
Mar 18, 2016 04:29 PM
