2009 G37x AWD coupe rack and pinion, remove and replace HELP
Old Dec 30, 2015 | 04:21 PM
oscaritote's Avatar
oscaritote
Question 2009 G37x AWD coupe rack and pinion, remove and replace HELP
So I have everything removed with except of the "knuckle" that joins the rack and pinion to the steering wheel shaft. I removed the bolt between knuckle and rack n pinion and also removed the bolt between shaft and knuckle. parts do seem a little rusty so sprayed WD40 on it for now, but i cant get them loose to be able to remove the rack and pinion out. Any suggestions or special tools to use for this 2009 G37x AWD coupe rack and pinion removal?
Thank you!
Oscar
ram18962
May 23, 2017 12:30 PM
TastefullyDoneG
Dec 18, 2016 10:04 PM
cizko37
Dec 28, 2015 08:43 AM
kleinwinnn
Dec 11, 2015 06:17 PM
pal51961
Dec 2, 2015 05:54 PM
