A Couple of rare mods would like your opinions with
Old Jun 18, 2016 | 02:41 PM
DevilsG37s's Avatar
DevilsG37s
Originally Posted by 4doorfury
The correction factor is going to ever so slightly inflate the numbers. I would ask the dyno operator if they could forward you the file with a correction factor of 1.01 for the last run. My guess is you would lose about 3-4whp across the range. Been a while since I have played with correction factors since dialing in my old turbo setup.
Here is run 9 which I took while still haven't done with the meth tuning but yet there is a noticeable gains. The factor correction for all is the same and the drop was less than 3-4 whp.
Old Jun 18, 2016 | 02:48 PM
DevilsG37s's Avatar
DevilsG37s
The correction for run 10 was automatically correcting the run to show the power output exactly as if ll the three run were taken in the same conditions. So there is nothing wrong about the power readings shown there.
Old Jan 20, 2022 | 09:59 PM
BigSpoon's Avatar
BigSpoon
I doubt anyone from 2016 is still around by now lol but I will ask anyway: how did your water meth kit hold up over time? I'm thinking about installing one as well. It's a used good condition one I have sitting in the garage off another car. How do you wire up to the factory MAF sensors?
Old Jan 20, 2022 | 10:39 PM
SkysG37's Avatar
SkysG37
I'd start by finding the instructions for the brand of meth controller you have.
I installed a Snow performance kit using online instructions.
It came with my used GTM supercharger kit (which I also found instructions online)
Old Jan 21, 2022 | 04:37 PM
BigSpoon's Avatar
BigSpoon
Thanks yea I'll look into it more... it's an AEM kit. Only has the one hose/nozzle though... and I need to figure out how to properly run a dual nozzle setup, 1 for each of our TBs... Hopefully you can run two off one pump and you don't need to like, run 2 complete water/meth kits for each intake side lol...
I couldn't find anything in the instructions so far about how best to integrate it with your MAF sensors since I'm not going to use a MAP input lol, maybe if I was FI
Old Feb 3, 2022 | 05:16 AM
SkysG37's Avatar
SkysG37
Yeah, I'm using MAP and upRev,Because supercharger and '08.So I didn't look into the MAF integration.
My meth injection plumbing includes an anti drain back solenoid and a simple tee fitting.
Old Feb 3, 2022 | 10:02 PM
BigSpoon's Avatar
BigSpoon
Talking
That's awesome - do you have any photos?! I'd love to see what the whole setup looks like. Did you use a separate fluid tank in the trunk or just tap into your windshield washer reservoir? Would love to see the t-fitting especially and where/how you put the nozzles in the intake piping?
Thanks
Old Feb 11, 2022 | 07:30 PM
spoolin03's Avatar
spoolin03
What happens if you do both methanol AND ethanol (E85) ? AND add some nitrous to that mix .
IPL G37
Jan 1, 2018 01:33 AM
socketz67
Oct 19, 2013 02:52 PM
GGTT
24
Aug 24, 2011 11:22 PM
