Auto Transmission fluid change - Nissan is full of it
Old Sep 3, 2019 | 10:33 AM
  #31
Baadnewsburr's Avatar
Baadnewsburr
Originally Posted by Eddie Elezaj
Just wanted to go over this alittle bit. RE7R01A transmission, which is the seven speed transmissions found in the G37 does not accept Valvoline Maxlife ATF. I worked at Valvoline for 4 years, maxlife atf is a very universal transmission fluid although is NOT to be used in the seven speed transmission G37. At Valvoline, all vehicle information is sent to us by The manufacturer. Nissan/Infiniti stated the seven speed transmission CANNOT take Valvoline Maxlife ATF, although the 6 speed automatic G35 CAN. Hope this helps,Valvoline Maxlife ATF overall sucks anyways, so dont put it into your car if its the wrong fluid
There is no 6 speed automatic G car...for the G35, theres a 5 speed automatic and a 6 speed manual...not sure which one you're referring to...
For context though, that post you quoted is almost 5 years old and Blnewt was probably the most active forum admin on here in that time and I'm almost positive that he never had any issues with running Valvoline Maxlife ATF nor have any of the ppl who have reported doing drain and fills with it in the massive DIY thread...so
imatt86
General Tech Questions
46
Jun 16, 2019 01:26 PM
Walks
13
Mar 9, 2017 02:27 AM
ryang37x
Sep 22, 2015 05:33 AM
tifosi
Apr 10, 2013 04:25 PM
berny32
Oct 26, 2011 03:36 PM
