Intake hood Scoops. (Discussion)
Old Nov 7, 2015 | 05:05 PM
DevilsG37s's Avatar
DevilsG37s
Hi,
I've been reading a lot about these intake scoops that act as a Ram Intake.
There is an article about it which I found very informative.
Here: An Explanation of Hood Scoops - Ate Up With Motor
I'll quote what I found most interesting which got me seriously thinking of doing this.
RAM AIR INTAKE
In any body of moving air (or other compressible fluid), the air’s static pressure is inversely proportional to its velocity. To take advantage of this principle, the cross-sectional area of a ram scoop’s intake plenum typically starts off small and gradually increases. As a result, air enters the plenum at high speed and then slows as the plenum widens. As fast-moving air continues to enter the plenum, air begins to pile up and its pressure increases. If this high-pressure air is admitted to the engine’s intake valves (assuming the pressure is not diffused before that), it can be used to provide a mild supercharging effect. A functional ram scoop generally also serves as a cold air intake, although the reverse is not necessarily true.
The benefits of even a properly designed and well-placed ram scoop can be difficult to quantify because the supercharging only occurs when the vehicle is moving and thus can’t be measured on a stationary dynamometer (unless you also have a wind tunnel). It can also be tricky to determine whether any power gain is due to the ram effect or simply the benefits of admitting cooler air to the engine. However, a good system under ideal conditions might conceivably produce a power gain of up to about 10%.
I wonder if anyone have done this.
What you guys think?
Old Nov 8, 2015 | 09:38 AM
PongSanity's Avatar
PongSanity
Hood scoops serve more of a purpose with top mount intercoolers. With SRI. I don't see the sense honestly. Id rather poor on a CAI.
Old Nov 8, 2015 | 05:33 PM
Landshark's Avatar
Landshark
some NACA ducts would be nice to cool down our hot-*** engine bays, but i dont feel like cutting holes in my hood. if you do that would be the way to go ...
Old Nov 8, 2015 | 06:59 PM
DevilsG37s's Avatar
DevilsG37s
There are some NACA ducts which serve as air intake. It would help more along with the existing intake.
Here are some pics to make things clear.
This is an air intake box for the M37. I would cut the stock box on the upper portion to open another inlet port Just like in the pics. Then the NACA scoop outlet will go into the open port with sealing it to only get air from outside of the engine bay.
This will help more the stock setup with aFe drop ins and some post maf silicone intake hoses.
Old Nov 11, 2015 | 08:11 AM
DevilsG37s's Avatar
DevilsG37s
Found a very interesting experience from someone with Honda S2000.
Check it out: Project S2000: Part 19 - Ram Air!!! Plus Hot Air Testing!
xjabboi
Feb 24, 2015 02:19 AM
It's a G thing
Motorsports / Track
Apr 16, 2010 07:32 PM
G37Rider92649
Picture Share G Coupe
27
Jan 9, 2010 12:14 PM
wbimota
Mar 23, 2008 02:36 AM
