HELP!!! Limp Mode
Old Sep 13, 2015 | 04:55 PM
ill12will8's Avatar
ill12will8
HELP!!! Limp Mode
HELP!!! So I come out the house start my car and it cranks, starts, then dies. I start it back up I get a CEL. I get out my scanner and check the code. I get P0021 Camshaft A. I clear it and it drove fine. Then I get out and go to the store. Come back and I'm driving and it goes into limp mode but without a CEL. I pull over and rescan it. Had a pending code for P0300 Multiple misfire. I clear it but still in limp mode. I get somewhere and pop the hood. Check the intakes and oil. I restart the car and is no longer in limp mode but has a pending code for P0300. Not sure what to do. I've only owned the car for about 15k miles. Currently at 117k.
Old Sep 13, 2015 | 05:00 PM
Depravity's Avatar
Depravity
How are your spark plugs? Or when was the last time those were replaced?
Old Sep 13, 2015 | 05:14 PM
ill12will8's Avatar
ill12will8
HELP!!! Limp Mode
I never replaced them
Old Sep 13, 2015 | 06:13 PM
Selym's Avatar
Selym
VQ37VHR? VQ35HR? Model year?
Old Sep 13, 2015 | 06:25 PM
ill12will8's Avatar
ill12will8
HELP!!! Limp Mode
It's a 09 G37x
Old Sep 13, 2015 | 09:56 PM
604gz's Avatar
604gz
HELP!!! Limp Mode
I had that code come up because i accidentally reversed the wires for number 5 and 3 coil
Possible issues
- Faulty spark plug (s)
- Faulty ignition coil (s)
- Clogged or faulty fuel injector (s)
- Intake air leak
- Fuel injectors harness is open or shorted
- Fuel Injectors circuit poor electrical connection
- Ignition coils harness is open or shorted
- Ignition coils circuit poor electrical connection
- Insufficient cylinders compression
- Incorrect fuel pressure
Old Sep 13, 2015 | 09:59 PM
ill12will8's Avatar
ill12will8
HELP!!! Limp Mode
Well imma change the spark plugs in the morning. Hopefully it'll help
Old Sep 14, 2015 | 11:27 AM
ill12will8's Avatar
ill12will8
HELP!!! Limp Mode
UPDATE!!! So I checked the spark plugs and they look new. I cleaned the mafs and tbs. Cranked the car up. Motor it out and ran it hard even took it to redline a few times. Then as I'm around the corner from home it starts jerking over 3k again. Pull a pending code p0300 again. I'm unsure what else to check.
Old Oct 20, 2015 | 08:07 PM
APillow's Avatar
APillow
did you ever fix this issue because i have the same model car as you and i just experienced a limp mode after a new hf cats and ctb exhaust. They also went and tuned it and found that it was knocking with max numbers.
Old Oct 26, 2015 | 12:21 PM
ill12will8's Avatar
ill12will8
Yea I changed the intake valve timing solenoid and its been working fine ever since. *knocks on wood*
Old Oct 26, 2015 | 10:09 PM
astat4's Avatar
astat4
check coils
MrRiv
Sep 29, 2015 04:59 PM
steven92
Sep 23, 2015 08:48 AM
pcwd
Sep 15, 2015 10:06 PM
drewfinity
Future Models
Sep 15, 2015 12:49 PM
