Ultimate Z1 Header thread
Old Oct 13, 2015 | 10:19 PM
  #61
chuckie311's Avatar
chuckie311
Drop A Gear and Disappear
here it is
Red is stock header Gen3 Berk HFC Ark Ported Plenum 4.08 gears no tune
Blue is Z1 Headers Gen3 Berk HFC Ark Ported Plenum 4.08 gears no tune
Green is ECUTEK tune Z1 headers Gen3 Berk HFC Ark Ported Plenum 4.08 gears
Old Oct 13, 2015 | 10:21 PM
  #62
chuckie311's Avatar
chuckie311
this is my ECUTEK tune vs no tune with mods below
Old Oct 13, 2015 | 10:23 PM
  #63
chuckie311's Avatar
chuckie311
and your welcome!!
so now we can say shorty's make POWER!!!
Old Oct 13, 2015 | 11:09 PM
  #64
Upscale Speed's Avatar
Upscale Speed
you only gained 3whp/6wtrq with the Ecutek tune? the 16whp/3wtrq over your baseline with the headers is nice to see. I'd venture down that road in the future. My only concern is fitment on the X models.
Old Oct 14, 2015 | 12:01 AM
  #65
conkus805's Avatar
conkus805
those are pretty good gains, congrats! I'm curious what you will gain from e85 when you go down that road. I may get there before you, I'm planning on doing the e85 switch in November.
Old Oct 14, 2015 | 12:57 AM
  #66
chuckie311's Avatar
chuckie311
Yep I didn't make much either with UPREV.. but ECUTEK is way better there is 0 dead pedal feel anywhere..the throttle is so responsive you touch the gas and go
Old Oct 14, 2015 | 12:58 AM
  #67
chuckie311's Avatar
chuckie311
yeah I wont be E85 till next year seeing I had to spend 600 to get new high flow because the Z1 ones were so poorly made..they didn't have anything I liked in stock and were charging a arm and leg to overnight them to me..
Old Oct 14, 2015 | 08:06 AM
  #68
ANMVQ's Avatar
ANMVQ
Throttle IS 1000% better once they dial it in Really looking for that sheet :/
Old Oct 14, 2015 | 09:36 AM
  #69
PongSanity's Avatar
PongSanity
I'm confused somewhere along the line... You made less overall power by switching headers, reverting to ported plenum, and changing final drive gears?
Old Oct 14, 2015 | 12:07 PM
  #70
chuckie311's Avatar
chuckie311
dyno sheet are up 16whp made over stock
Old Oct 14, 2015 | 12:10 PM
  #71
chuckie311's Avatar
chuckie311
nope power band has changed with the gearing...
https://www.myg37.com/forums/engine-...-new-dyno.html
I don't think anyone has done a dyno after changing gears..you don't lose power the power band just shift's with the gears..
If I was to switch back to stock gears I would probably be around 330whp or more..
Old Oct 14, 2015 | 11:45 PM
  #72
conkus805's Avatar
conkus805
I made less power with my gears, it has to do with the load values, the 3.3 gears put more load on the engine so dyno numbers will be higher. he would probably be around 330 ish whp like he said. seb explained it to me last time my car was on his dyno. I have 3.90 gears and made 297whp with Takeda Cai and ark grip catback and ecutek.
Old Oct 15, 2015 | 01:00 AM
  #73
chuckie311's Avatar
chuckie311
only issue I'M having is the ECUTEK keeps throwing Speed Sensor codes.we have tried changing the Gear ratio and it doesn't do anything.don't know if its a bug in the software or something else.i reset them and the come right back soon as I turn the car off and on
2321: Performing DTC Operations on Nissan 370z Engine ECU 2009MY ->...
2321: Reading DTCs...
2322: P0500 - Vehicle Speed Sensor "A"
2322: P1574 - ASCD vehicle speed sensor
2322: 2 DTCs Read
2322: End of DTC Operations on Nissan 370z Engine ECU 2009MY ->...
2322:
Old Oct 15, 2015 | 09:40 AM
  #74
ANMVQ's Avatar
ANMVQ
Oh sorry I honestly saw the 310 WHP and assumed this was before the ECUTEK tune. :/ ..
Old Oct 15, 2015 | 09:59 AM
  #75
PongSanity's Avatar
PongSanity
I guess i learned something new today. I thought the power (well more so mid range power) wouldve been more due to the gears. esp. i thought the torque wouldve been higher... fine gains made by the headers... in for a sound clip.
