Ultimate Z1 Header thread
Old Aug 13, 2015 | 06:44 PM
chuckie311's Avatar
chuckie311
Drop A Gear and Disappear
Originally Posted by micafd3s
roughly 160 per whp if it does come out to be a gain of 15whp..
wonder what the net is for goin FI.. of course I realize the 15whp is just headers.. but still seems high
not lookin to start a debate here.. just wonderin since im still tryin to see what path to go.. NA or FI..
after I get the headers I am done..
I couldn't see going FI as a Stillen supercharger I just don't like..
but if you break down the cost of going FI your looking at 15k +plus if your auto as the transmission will be the first thing to go..twin turbo is they only way I would go
Old Aug 13, 2015 | 11:06 PM
micafd3s's Avatar
micafd3s
ive owned close to a dozen cars that were turbocharged.. single and twin..
points of failure seems higher than that of a supercharger... lookin to try something different..
but would be lyin if i said i wasn't oogling over the aam turbo kit.. im 6mt btw..
good luck with the install.. perhaps good numbers from your setup might swing me back to the NA thought...
Old Aug 14, 2015 | 11:22 AM
ANMVQ's Avatar
ANMVQ
Originally Posted by chuckie311
you're HFC wont work unless you change the flange.. they use DE flanges from the 350z..
i am running berk HFC now but will sell them when i switch over to the headers
Not unless theres a play on words but his is right from their sight,
however they can be used on 07+ VQ35HR and VQ37VHR engines with the use of Stock DE Catalytic Converters, Z1 High Flow Cats, Z1 Test Pipes, or the Cat Delete Y-Pipe
An I have Z1 HFC's or are they say Z1 cats for a DE , Yea called , I'm out I'm not swapping cats again .
Old Aug 16, 2015 | 11:41 AM
MaQG37's Avatar
MaQG37
With all the Z1 stuff you have, you should contact them and see if they would send you their Z1 CAI to get dyne results.
Old Aug 16, 2015 | 12:33 PM
chuckie311's Avatar
chuckie311
i'm not sure if Z1 has their own CAI..ill have to look when their site is back online..but I would stick with the Stillen CAI.
I need to head to the track this winter and get some 1/4 mile times..
as of yesterday my dyno numbers have totally changed since im running with the 4.08 gears now..
Old Aug 16, 2015 | 10:05 PM
Sway_NV's Avatar
Sway_NV
I'm too young to die!
Wait, your dyno numbers changed with just the 4.08s?
I wonder if FI would make a flange that would connect with the z1 headers... I'm trying to stay away from any rasp and not try and make the car TOO TOO loud under normal driving... Keep in mind I have a GTHaus exhaust lol so I'm pretty set on RHFCs instead of any other hfc
Old Aug 16, 2015 | 10:28 PM
chuckie311's Avatar
chuckie311
Yes they did..while I was down getting my rom dumped to move over to ECUTEK i had a dyno done. New dyno number are 301whp and 249tq.
but trust me the car is way faster with these gears..
I asked my tuner and he said that the load changes with the gears..
Look at my new thread new dyno..
https://www.myg37.com/forums/engine-...-new-dyno.html
Old Aug 17, 2015 | 03:56 PM
PongSanity's Avatar
PongSanity
so here's a vid of a G37s pushing 347whp 285wtq with z1 headers paired with art pipes and tomei single exit exhaust.
z1 looks like they're winning.
Old Aug 17, 2015 | 04:19 PM
chuckie311's Avatar
chuckie311
good numbers but to bad we don't know the before and after gains..this is why I am doing this thread..
my dyno numbers have changed since I did the 4.08 gears glad I did some test pulls this weekend and found that out..i'm going to get some 1/4 mile times this winter.. even though I know they will suck with the track being 1950ft
Old Aug 17, 2015 | 08:58 PM
ImmortalsReign's Avatar
ImmortalsReign
Tuning in for your results.
I won't be able to do it unless I change my CATs(FI), probably won't but still interested non the less.
Old Aug 17, 2015 | 09:35 PM
ANMVQ's Avatar
ANMVQ
Not to take away from those numbers but man that thing sounded like a weed whacker :/ .
I to each their one but ugh
Old Aug 17, 2015 | 10:58 PM
PongSanity's Avatar
PongSanity
It doesn't sound that bad to me however I don't think a single exit exhaust would ever be an option for me.
Old Aug 17, 2015 | 11:10 PM
Upscale Speed's Avatar
Upscale Speed
Can't wait for your results. I've always wanted headers but have been talked down from getting them so many times here. Maybe the gains will be significant enough for me to take the leap. Your thread will be important for a lot of us on the fence.
Old Aug 18, 2015 | 02:49 PM
  #29
ANMVQ's Avatar
ANMVQ
But you'll have to sell you FIRHC's and buy Z1 DE cats . Reason I will probably pass on these ,
Old Aug 18, 2015 | 03:25 PM
  #30
PongSanity's Avatar
PongSanity
I'll be doing this. Buying the headers/test pipes then selling my f.i. hfc ... op and i got similar mods so his final numbers would be ball park to where I wanna be.
