Low oil pressure light coming on at idle only
Old Mar 10, 2015 | 09:28 PM
  #31
Great news!
Now you can have some real fun w/ that $2k plus that you were already setting aside
Old Mar 10, 2015 | 09:38 PM
  #32
vqsmile's Avatar
vqsmile
Originally Posted by asbyo
Wanted to also quickly ask something to those who have installed an aftermarket Oil Pressure gauge. I kind of want to do this... Was considering putting it on the A-Pillar, too, just because I loved that location in my turbo saleen for 2 gauges and I don't want to modify the dash locations I have seen. I was looking for maybe an Autometer version--anyone have a link or an idea of the best place to buy? Anything I should look out for while doing this? Also any ideas on a second gauge that might help me keep an eye on things? Was thinking of doing a wideband A/F setup but I know those can get pricey. Not boosting so fuel pressure is almost irrelevant.
Glad your issue turned out to be a (relative) non-event. You really couldn't have gotten much better news!
As far as gauges go, I have to say there aren't a whole lot of opportune locations, at least not any that don't look like an afterthought. The pillar sounds about as good as any. If you are just daily driving the car, I suggest a coolant temp gauge to go along with the OP gauge.
When I hooked up a ScanGauge and observed real temp readings in my car, I found the factory coolant temp gauge to be pretty lame, quickly rising to its 'normal' range even when the engine was still relatively cold (140*), and other times remaining in that same 'normal' range even when the temps were considerably higher (230*).
Seems this is somewhat common any more for manufacturers to do; don't want to scare all the customers with needless worries about a pesky needle moving around all the time, better to just leave it sit there motionless in the middle. To me, that's not of much use at all. They've clearly stroked all linearity out of it, and dampened it as well. I hate having a false sense of security, so if I were to add another gauge, it would be coolant temps.
I agree with BB though, if you're going to be running the car on a track, you really need to know oil temps.
I made a few notes in the thread I made (on testing your OP) regarding hooking up the OP gauge. There's not really anything new or special there; if you've hooked up a gauge before you shouldn't have any problems. I went with an Autometer digital gauge that I just picked it up off of Amazon.
.02
Old Mar 11, 2015 | 12:51 AM
  #33
antirice's Avatar
antirice
You can buy a bluetooth ODBII adpater and you will be able to see a bunch of interesting data from the ECU. But unfortunately oil pressure is not one of them so you would have to installed an aftermarket gauge.
Here's what my "Torque" (an Android app that displays ECU info) looks like
Old Mar 11, 2015 | 06:36 PM
  #34
asbyo's Avatar
asbyo
Great to hear that the gauge was the problem and not the biggie that some of us have had. When you said the pressure had already been replaced, I thought the worst. Glad it was just a bad part or bad work and not the horrors of Nissan's ineptitude in engineering that bit you in the but.
Score one for the good guys. If you track, I'd put an oil temp gauge in the second pod.
Thanks BB. Really appreciate your honest insight and direction in this thread (and others). You helped prepare me for the worst, but I will be the first to admit that I dodged a bullet. For now, it's about damn time I do. Like I have said that in the past, I have been through some horror stories. Whether it was with my fully built 76mm turbocharged Saleen or with my stock BMW 335i, I got some to share over some drinks.
Great news!
SERIOUSLY. I have my GTR fund which I do NOT want to touch.
.02
Thanks for the advice. That's what I am leaning towards--just grabbing an Autometer digital off of amazon. Probably going to jump on that this weekend. Might pick up a little toy this weekend at the same time from my local Yamaha dealer, too. Lucky me!
Pretty cool technology. Not too sure I would benefit by having it on my phone since I want live results that aren't too hard to **** my head and view, but it's definitely cool. Once upon a time I looked into the screen replacement things that some have done. Too much work for not enough reward IMO, but cool none-the-less.
Old Mar 11, 2015 | 07:08 PM
  #35
asbyo's Avatar
asbyo
Hate to de-rail this thread past the original intention, but what options do I have for mounting these? I just now looked and I can't find an A-pillar gauge that would work well. I have a black/black but the a-pillar area is wrapped in tan. I don't want a black gauge pod. Ideas?
Here's the gauges i'm going with:
Amazon.com: Auto Meter 3337 Sport-Comp Electric Water Temperature Gauge: Automotive Amazon.com: Auto Meter 3337 Sport-Comp Electric Water Temperature Gauge: Automotive
Amazon.com: Auto Meter 3321 Sport-Comp Mechanical Oil Pressure Gauge: Automotive Amazon.com: Auto Meter 3321 Sport-Comp Mechanical Oil Pressure Gauge: Automotive
Old Mar 12, 2015 | 12:45 PM
  #36
vqsmile's Avatar
vqsmile
You could always paint the pod to match the interior color. SEM makes some excellent paints for plastic and come in very large color pallet.
Mechanical eh? Do you really want to plumb hot pressurized oil into the cabin of your car?
If you do, I'd at least make sure to find one with an operating range that is broader than the normal pressure range the car produces (i.e. 100 psi is too low).
Old Mar 12, 2015 | 08:23 PM
  #37
asbyo's Avatar
asbyo
touche... good point, duh. =p thanks
Old Aug 18, 2015 | 07:43 PM
  #38
Gia_37s's Avatar
Gia_37s
bumping this thread for new info! which OP gauge did you end up going with, mounting location, hows the op been since then?
superjoey
31
Mar 22, 2023 11:56 PM
WolfSongX
Car Care & Detailing
May 10, 2017 07:26 PM
the dreame
Apr 9, 2017 10:30 AM
Thedbarz
33
Feb 9, 2016 12:05 AM
