AT Shifter Assembly Replacement
Old Sep 21, 2014 | 01:52 AM
beto4632's Avatar
beto4632
Question AT Shifter Assembly Replacement
Took my car to the Dealer this Friday, can came up that I need a new Shifter Assembly, its having problems locking in park on any surface but mainly uphill or downhill.
They quoted me at $680. I have a G37X will any AT Shifter Assembly fit like a base or a S type, and has any one done this before as a DIY. Want to see if this task can be done by myself.
Old Sep 22, 2014 | 03:07 PM
terrycs's Avatar
terrycs
Replacing a shifter assembly is easy, at least on a non-x.
What I find interesting though is that the shifter assembly does not really "hold" the car in park. The shifter assembly is connected to the transmission via metal linkage to move a lever on transmission housing.
It's usually the engaged parking pawl inside the transmission that holds the car in park.
Is the shifter assembly actually coming out of the P position?
Old Sep 22, 2014 | 08:09 PM
beto4632's Avatar
beto4632
If I am unable to fully lock it in the P position it does come out and im able to switch it between R and N. Its weird everything else works D DS and Manual mode. The only problem im experiencing is for it to fully lock in Park.
Old Oct 21, 2014 | 03:49 AM
darrick's Avatar
darrick
i have this same problem started today on my 2008, funny thing is i never had a problem till i pulled off the shiftier trim and it started beeping don't know what i could of done wrong ?but it looks like when i put it in park the white hook lock is not coming up to the locked position, i can pull the shiftier back to drive and then push up the lock ,i don't understand what happened ?
Old Oct 21, 2014 | 09:00 AM
darrick's Avatar
darrick
Anyone else had this problem ? I am driving around real getto right now
Old Oct 21, 2014 | 09:51 AM
ANMVQ's Avatar
ANMVQ
So the push button on the shifter doesn't need to be pressed to shift out of park? And when you put it in park that button doesn't pop? Maybe there is a cottar pin that came off inside the center console?
beng37s
Intake and Exhaust
Sep 19, 2015 01:32 PM
VIVID
Sep 14, 2015 03:31 PM
SuicidalG37SGuy
Sep 10, 2015 06:01 AM
joshferbs
Sep 9, 2015 08:53 PM
Falker11
