check engine light
Old May 4, 2014 | 07:24 PM
09 G37xs's Avatar
09 G37xs
check engine light
Hey guys recently my check engine light came on i found two codes P0171 and p2A03. Any idea.
Old May 4, 2014 | 09:28 PM
RPG11's Avatar
RPG11
For P0171 Check for intakes air leak, clean air filter, and clean the Sensors. Could be from CAI if you have some. The second p2A03 sensor comes on if you have test pipes and/or high flow cats, also come on if catalytic are bad. if is because of test pipes you're going to need defoulers. Then reset your ECU. You should be good to go
Old May 17, 2014 | 11:19 PM
09 G37xs's Avatar
09 G37xs
Thanks a lot i will try those..but i dont have any test pipe .everything is stock
Old May 18, 2014 | 02:47 PM
RPG11's Avatar
RPG11
Then you might want to check your catalytic converter for any holes or maybe they just need to be replaced? how many miles do you have on them?
Old May 19, 2014 | 06:53 AM
08Gsmith25's Avatar
08Gsmith25
sounds like a good excuse to get hfcs, since they are probably cheaper than factory cats. get some de foulers while you are at it
superjoey
31
Mar 22, 2023 11:56 PM
Thedbarz
33
Feb 9, 2016 12:05 AM
STownSaint
Aug 29, 2015 09:04 AM
moy92
Aug 20, 2015 08:43 PM
moy92
Aug 19, 2015 05:30 PM
