Help how to change the maximum engine speed of VQ37VHR
Old May 4, 2014 | 05:04 PM
Glover998's Avatar
Glover998
Originally Posted by warped ideas
My Rev limit was increased to 8500 with the Uprev tune. I'm speaking of the point where my relatively flat torque curve starts dropping off even with more RPM. It starts around 7300 rpm and steadily drops. I have only really bounced off the rev limitor twice.....
Dude .. go back to my reply and read it carefully, Thank you.
Old May 9, 2014 | 08:02 AM
enzo0706's Avatar
enzo0706
Originally Posted by Varjo
AFIK, it doesn't exactly add more power. Our cars generate peak power before redline. What it does do, is allow you to better straddle peak power as you shift without bouncing off the rev limiter. I now some people who are hardcore drag racers benefit from this sort of thing. For any sort of daily driving, honestly even for non-drag track driving, I don't think you'll see any benefit at all.
Sorry , I am from China , Some word i do not know the meaning ,
what is the meaning ot this ? straddle peak power as you whift without bouncing off the rev limiter ?
Can you explain it ?> many thanksssss bowdown:
Old May 9, 2014 | 09:16 AM
RPG11's Avatar
RPG11
You will be able to hit peak power and have time to change gears before your hit the top off the rev limiter. If you wanna see what i mean throw it on first and gas it you'll see how the you cant go past 7500 and the needle bounces of.
Old May 11, 2014 | 01:14 AM
enzo0706's Avatar
enzo0706
all of you mean this product ?
Error - Hypertech
Old May 11, 2014 | 01:15 AM
enzo0706's Avatar
enzo0706
any times we can use this as detali ,...
Max Energy Sport Power Programmer Delivers The Maximum Tune
Max Energy Power Tuning extracts every bit of energy possible out of every molecule of fuel giving you more miles at part-throttle and more power at wide-open throttle. In order to increase engine efficiency, horsepower and torque, our engineers first make hundreds of dyno runs to optimize the spark and air-fuel curves point by point over the entire rpm band from just off idle to wide open throttle. Next we take the vehicle with the new tune to the track and the street to verify real world performance gains. The results…maximum power, quicker acceleration, smoother shifting and better driveability.
The Max Energy Sport not only gives you the power you crave but also offers specific features for your make, model and year.
Programmer Features
Note: Adjustable features depend on year, make and model of vehicle. For a particular vehicle's features please use the "Search by Vehicle" at the top of this page.
Hypertech Power Tuning
Higher compression ratio engines and engines with superchargers or turbo chargers were designed to use only premium octane, so only one (1) Power Tuning program for premium octane is provided. But, if your car or truck came from the factory capable of using more economical regular octane, then two (2) optimized tuning programs are provided: one for premium, and the other for regular. In most cases, Hypertech’s exclusive Power Tuning for regular octane provides excellent power gains, almost as much power as premium octane. If you are using premium octane, and you want all-out, maximum power, then select premium octane Power Tuning.
Top-Speed Limiter
Automobile manufacturers limit a vehicle’s top-speed to match the speed rating of the factory-installed tires. If you have installed tires that have a different speed rating, the Max Energy allows you to raise or lower the vehicle’s top-speed limiter to match the speed rating of the newly installed tires. A tire’s speed rating for maximum safe speed under perfect conditions is marked on its sidewall. Always obey all traffic laws when driving and only use this feature for off-highway competition in sanctioned events.
0-60 Throttle Restriction
The "selectable throttle restriction" tunes the engine control systems for better low speed performance without sacrificing driveability, but it does not disable the torque management completely. There are many different torque management systems active at any given time while driving. During our tuning development we altered most of these systems in different combinations to assess the impact on performance, and driveability. We took the best combination of those changes and combined them with further tuning to improve the overall performance and driveability under all driving conditions. The overall affect was so dramatic we felt that all customers would benefit more if the changes were user selectable rather than "forced."
V-TEC Controller
Some Honda and Acura vehicles have engines that are equipped with Honda¹s VTEC camshaft technology. Under certain driving conditions, specifically higher RPMs and heavy load, the engine controller engages additional camshaft followers which use a more aggressive camshaft profile. This increases airflow in and out of the engine which increases power output. The Max Energy Sport Power Programmer allows you to adjust the specific engine speed that the VTEC camshaft profile engages to customize the power band of your engine to match the power gains of the Max Energy Power Tuning and any additional bolt-on power adders.
RPM “Rev” Limiter
In today’s vehicles, the onboard computer controls maximum engine rpm. The stock computer is programmed to shut down the engine when it reaches its redline. But if you have modified your vehicle to increase its high-speed performance, more rpm means more power. When you shift gears with the stock rpm limit, the engine falls back to below the peak of its horsepower curve. When you extend the engine’s rpm range with the Max Energy Power Programmer, your engine has more power available after gear changes. By adjusting the maximum rpm to keep the engine in the “sweet spot” of its power curve, you can increase the average horsepower that accelerates the vehicle.
Read & Clear Diagnostic Trouble Codes(DTCs)
If you get a “check engine” light or “service needed” message, the Max Energy will allow you to read the code and gives you the ability to clear the code and turn the “check engine” light off. You can then make the necessary repairs to prevent the light from coming back on.
Return To Stock Or Change Option Settings
Hypertech’s Max Energy downloads and saves the stock tuning program, then uploads your customized Power Tuning program. Before taking your vehicle into a dealership for service, always return the vehicle’s computer back to the factory programming. Once you have the vehicle back from the dealership, reinstall the Max Energy Power Programming as before. The Max Energy can only be used on one (1) vehicle at a time, so if you sell your vehicle or want to use it on a friend’s vehicle, simply return your vehicle to the stock tuning program and you may then use the programmer on another vehicle that is covered in the same part number.
Internet Updateable
The Max Energy Power Programmer comes with a USB cable and a CD containing software to enable quick updates over the internet. If your vehicle has a new calibration not available when your Max Energy Power Programmer was manufactured, it is possible that you will see a “Cal not found” message on the Max Energy screen. If this occurs, you can simply update your Max Energy with the correct new calibration via the internet. Simply connect the Max Energy (using the provided USB cord) to your computer and go to Performance is our Passion - Hypertech. Then click on the Support button to get update downloads. You can also get the update downloads using the CD which also contains an installation video and a printable version of the instruction manual.
Old May 11, 2014 | 01:43 AM
enzo0706's Avatar
enzo0706
share some more other info of this production
Old May 11, 2014 | 01:28 PM
Adam West's Avatar
Adam West
See my post above, they Hypertech cannot increase the rev limiter on the G37, only decrease it! This will not work for you.
Thedbarz
33
Feb 9, 2016 12:05 AM
