Broken piece in engine bay?
It can be fixed!
Some epoxy glues may work on this plastic but some won't. 3M makes a plastic repair epoxy especially for plastic parts which might be flexible or work on flexible connections. It's called Automix #5887 and is used by most body shops to repair damaged plastic parts of all types. Sets in around 10 minutes and should do the trick. Good luck.
Al
Al
I think I broke the exact same piece trying to install the Z tubes. My understanding is that it's unnecessary. Let me check my posts as well.
Is this it?
Is this it?
Right, because car companies just love to stick stuff under the hood for no apparent reason...
