Who uses their Paddle Shifters?
Old Mar 25, 2014 | 04:37 PM
kOrE's Avatar
kOrE
I know I will probably get chastised for this but I don't use my paddle shifters at all. It just feels so un-natural to me. Maybe because my last 2 cars were manuals with a "real" clutch. Paddle Shifters just seem like a gimmick to me. I mean. . . my Wife's 2010 MDX has paddle shifters. . . .why?
(Kind of started this conversation in another thread (https://www.myg37.com/forums/newbie-...7-vs-335i.html) and figure'd it deserved it's own thread)
Old Mar 25, 2014 | 04:44 PM
'11G37S's Avatar
'11G37S
A 1/4 mile @ a time
I've used mine a couple of times. There is too much processor lag IMO. I took a video a while back of me driving some back roads using them and they were kind of loud, which was annoying because that was the only sound my camera really picked up.
I'd use them more if it didn't take a full second to shift gears.
Old Mar 25, 2014 | 04:46 PM
G37Sam's Avatar
G37Sam
It was the closest it got to a manual before I swapped to an MT. I loved the fact that I was selecting my gears and these tunnel downshifts with a catless FI exhaust setup made it very well worth it. The lag killed me though.
Old Mar 25, 2014 | 04:47 PM
rm2342's Avatar
rm2342
I do quite a bit. I'm trying to get into the habit. If I have to have my first automatic car, I might as well simulate a manual to some extent.
I definitely use them on the highway when slow people **** me off, blip blip down to 4th and see ya.. they work alright.
Hoping to get some relief from a tune potentially in the future.
Old Mar 25, 2014 | 04:48 PM
Drive Clean's Avatar
Drive Clean
I'm in the same boat, I find the paddles take too long to shift so I rarely ever use them. I prefer shifting in DS mode on the 7AT, seems to me that it has less lag than the paddles.
Old Mar 25, 2014 | 05:01 PM
stiizy's Avatar
stiizy
way too much lag, rather just use the shifter.
Old Mar 25, 2014 | 05:15 PM
RexHavoc's Avatar
RexHavoc
I use them here and there but the lag.... So disappointing.
Mostly for coming on and off the highway, not a lot.
Old Mar 25, 2014 | 05:19 PM
ANMVQ's Avatar
ANMVQ
I use mine ever day, LOL
Old Mar 25, 2014 | 07:39 PM
forrmark's Avatar
forrmark
They seem like just a decoration on the steering column to me. The acceleration with the 7 speed is plenty fast for me.
Old Mar 25, 2014 | 08:02 PM
PERMAT's Avatar
PERMAT
Been using mine more and more to control revs at initial startup and shift when my water bottle is in the way. Agree with Drive Clean,DS shifting seems better
Old Mar 25, 2014 | 08:43 PM
malady's Avatar
malady
I use mine but I do get smoother shifts from the actual shift ****
Old Mar 25, 2014 | 09:34 PM
guyinswmo's Avatar
guyinswmo
I've messed with mine some since I got my G about a month ago. I'm trying to adjust to the lag too. Nothing sucks worse than getting on it and missing your shift by a split second. About 90% of my daily commute is interstate driving so unless I'm running errands or something I don't get much of a chance to use the paddles or ds mode.....
Old Mar 25, 2014 | 09:52 PM
Di3s3l_power's Avatar
Di3s3l_power
I'm using around town more often, keeping the revs higher than normal D
using 3rd and 4th gear around 40mph.
I got used to the lag, and is not so bad
I wish the gear changes at redline were as crisp as gear changes at 4k ~ 5k rpm
shifting at redline there is a sensation of gears / "clutch" slipping
Old Mar 25, 2014 | 10:27 PM
monty2003's Avatar
monty2003
I use mine when passing or when I need to merge aggressively. It more for convenience (reaching with finger vs moving arm to shifter) and so I can keep two hands on the wheel. I really only kick it down a gear or two while cruising on the highway.
Agree that there is way too much lag to use in low gears. WHen starting from a stop the RPMs build so quickly in 1st and even 2nd gear that pulling the paddle is a guess and I end up shifting too early (or bouncing off rev limiter). 7AT is way better than me guessing when to shift with the paddles.
Brian
Old Mar 25, 2014 | 10:56 PM
1G372nv's Avatar
1G372nv
A ground wire kit will help with the lag many have mentioned. But I like using mine, for me there is a little fun factor there! Lol! Definitely not like a MT but if you have to have a AT IMO the paddle shifter makes it similar to stick.
