7AT shift knob
Old Mar 24, 2014 | 10:06 PM
doublea88's Avatar
doublea88
Originally Posted by Adam West
This is the M45 shift ****, I too ordered and installed one of these several years back and it is a worthwhile and easy upgrade. It has held up very nice and looks higher-end than the stock G ****. As others have mentioned, it's an easy upgrade to do and requires a dremel to make a couple of new notches in the metal shift mechanism for the lock to attach to. I've never had any problems with the **** coming loose.
I really like this **** but couldn't find the vendor on here to buy one. Or if anyone is looking to sell theirs.
Old Mar 24, 2014 | 10:20 PM
RexHavoc's Avatar
RexHavoc
You should be able to get it from any Infiniti dealer
Old Mar 28, 2014 | 05:11 PM
bri's Avatar
bri
Originally Posted by RexHavoc
It's a 2010. Not sure I like the wood but changing it low on the priority list.
I would be interested if you ever get rid of it.
Old Mar 28, 2014 | 05:25 PM
speedracer g37's Avatar
speedracer g37
masking tape the leather and use 2000 grit wet/dry to get the scratches out. then metal polish.
Old Mar 28, 2014 | 07:54 PM
RexHavoc's Avatar
RexHavoc
Sounds good, I'll keep you posted. I have a couple thoughts of the direction I want to go in but we'll see what happens.
Old Mar 31, 2014 | 09:41 AM
pcwd's Avatar
pcwd
RexHavoc - how did you do the reverse blue stitching?
Did you have to remove the small metal trim piece with the shift letters on it, or the whole wood grain piece?
Do you have pictures or instructions on how to do this?
Thanks.
Old Mar 31, 2014 | 10:03 AM
ANMVQ's Avatar
ANMVQ
Originally Posted by KEG97
Mine is scratched up too. I was going to see if the dealership would replace it under warranty....just like they did for the steering wheel surround piece.
Did they replace it mine, Mine is horrible, The wheel trim also a 09.
Old Mar 31, 2014 | 03:14 PM
mtenhoven's Avatar
mtenhoven
You might want to check out a Momo shift ****. That's what I used. Check the DIY. It should be in there if memory serves...
Old Mar 31, 2014 | 06:47 PM
RexHavoc's Avatar
RexHavoc
Thanks.
I followed this DIY https://www.myg37.com/forums/d-i-y-i...stitching.html
Had some trouble getting the whole thing lifted out but once I figured it out it went quick. The whole piece needed to come out them you unscrew the bottom and pull the leather boot out. You'll need a zip tie to put it back together as well. I think it took about 4.5 hours from start to finish. That was on pain meds so maybe a little longer or shorter?
Old Mar 31, 2014 | 11:11 PM
pcwd's Avatar
pcwd
I can't seem to pull the whole piece out (silver part and wood part). I've taken the shift **** out, and the pin out. Tried to lift up but it won't move. I didn't want to break anything.
Thanks anyway.
37
Oct 17, 2020 11:12 AM
Jonesmeister11
Sep 27, 2015 08:28 PM
Allboutcali
Sep 26, 2015 03:43 PM
Sep 25, 2015 01:38 PM
