Is my clutch going out ??
Old Oct 22, 2013 | 04:11 AM
jdubg37's Avatar
jdubg37
If I'm in second gear or 3rd or 4th or 5th and cruising and I step on the gas the Rpm's go up about 2k then drop back down and car grabs and takes off. But If I floor it starting in first gear and go through the gears it doesn't slip at all. What do you guys think It is
Old Oct 22, 2013 | 05:18 PM
JSolo's Avatar
JSolo
Just say no!!!!!
Lugging the engine.
Get above 2K or more before nailing it.
Old Oct 22, 2013 | 05:39 PM
jdubg37's Avatar
jdubg37
Ya I'm around 3k and punch it in third fourth or fifth gear and it goes up almost 2k Rpm's then drops and grabs
Old Oct 22, 2013 | 05:41 PM
telcoman's Avatar
telcoman
If driven properly a clutch in a MT should last 200k miles
My 06 G35 just before trade in still on the original clutch.
No slipee
Telcoman
Old Oct 22, 2013 | 06:03 PM
JSolo's Avatar
JSolo
Just say no!!!!!
Jdubg37,
My bad, I read your OP wrong. Might still be a slipping clutch. Either that or pressure plate has lost some of its 'pressure'. I think there might be some other threads on here on how to test for a slipping clutch. This happen suddenly or over time? What's your driving style, are you aggressive with it, slipping alot at take offs? Miles on the car?
Generally, it seems like 40-60K is about what these are good for. Albeit, some get much more, 80-100K, but all depends how you drive it.
Old Oct 23, 2013 | 12:11 AM
jdubg37's Avatar
jdubg37
It's an 09 with 36k miles just bought it to weeks ago so the dealer is paying to fix it. It only slips when I'm in the gear and get on it but does it in every gear second through 6th
Old Oct 23, 2013 | 12:12 AM
jdubg37's Avatar
jdubg37
It's an 09 with 36k miles just bought it to weeks ago so the dealer is paying to fix it. It only slips when I'm in the gear and get on it but does it in every gear second through 6th gear
Old Oct 24, 2013 | 04:36 PM
jdubg37's Avatar
jdubg37
Took it to infiniti they said it's the clutch and hopefully they don't have to replace the flywheel too
Old Oct 26, 2013 | 11:38 PM
jdubg37's Avatar
jdubg37
Getting a new clutch and flywheel as we speak
jdubg37's Avatar
jdubg37
Getting a new clutch and flywheel as we speak so everything should be good now
ZSpeedPerformance
Drivetrain
12
Sep 9, 2016 11:20 AM
stevo4756
Oct 9, 2015 01:54 AM
r0cketm0nkey
Sep 27, 2015 01:34 PM
r0cketm0nkey
Sep 18, 2015 10:16 AM
inspector94
Sep 8, 2015 12:57 PM
