What might this be ?
Old Oct 20, 2013 | 01:57 AM
jdubg37's Avatar
jdubg37
I Have a 09 g37s coupe 6spd and if I'm in any gear cruising and get on it a little bit the clutch goes up about 2k Rpm's comes back down and then grabs and takes off. Is this normal
Old Oct 20, 2013 | 10:12 AM
Adam West's Avatar
Adam West
Hrmm, sounds like it could be the clutch is slipping under power. From my other manual cars, the test is to put it in an upper gear and get on the gas to see if it slips. Either that or something is going on with the slave cylinder.
Old Oct 20, 2013 | 03:22 PM
JRMG37S's Avatar
JRMG37S
Yep, clutch is slipping.
Old Oct 20, 2013 | 05:22 PM
jdubg37's Avatar
jdubg37
How long until it goes out completely
Old Oct 20, 2013 | 05:23 PM
jdubg37's Avatar
jdubg37
Will it last awhile before it goes out completely ??
Old Oct 20, 2013 | 05:44 PM
Bladerunr's Avatar
Bladerunr
It depends on how hard you drive and how you launch from 1st gear. If you baby it, you might get a few months out of it.
Old Oct 21, 2013 | 01:14 AM
jdubg37's Avatar
jdubg37
But when I floor it from a dead stop and go through all 4 gears it doesn't slip at all
Old Oct 21, 2013 | 01:16 AM
jdubg37's Avatar
jdubg37
When taking off from a dead stop and going through all 4 gears it doesn't slip at all
Old Oct 22, 2013 | 03:21 AM
jdubg37's Avatar
jdubg37
You guys still think this is the problem is the clutch ?
Old Oct 22, 2013 | 10:28 AM
JRMG37S's Avatar
JRMG37S
Put it in 6th gear around 2000rpms now floor it..
If the clutch is good the car will take off slowly, if the clutch is bad the rpms will shoot up and the car won't accelerate.
