Crusie control cut-out switch
Old Sep 27, 2013 | 12:25 PM
I have broken my cruise control cut-out switch, also known as the cruise control release switch. It looks exactly like this one:
It is the one that sits above the clutch pedal arm and is normally depressed only when the clutch pedal is in the full up position, not the one that depresses when the clutch pedal is pressed down. For those that are knowledgeable, I need some confirmation. I believe that the car should still start and drive normally (I have not finished reassembling everything with the clutch pedal assembly to find out for certain) and the only thing that will be affected is that I will be unable to use cruise control. Is this correct?
Old Sep 27, 2013 | 05:32 PM
Finished install and found my own answer before anyone posted it. FYI, everything works normal except cruise control doesn't work, just as I thought.
vamarris
Dec 9, 2018 11:10 AM
Upscale Speed
Dec 26, 2015 08:45 AM
2K1 6T8
Oct 6, 2015 07:40 PM
parkern
Oct 1, 2015 10:15 PM
Landshark
Sep 29, 2015 11:20 PM
