Weird engine noise *video included*
Old Aug 17, 2013 | 05:35 PM
unknowndesi's Avatar
unknowndesi
My car has over 100k miles on it, I've maintained it all myself (I've worked in a shop so I think I know what I'm doing)
The front of the engine (timing chain cover area) has this weird constant noise it is constant with rpm, so the higher the rpm the louder the tick. Almost sounds like marbles in the timing chain cover
Please see video attached
Thanks for the help guys
Old Aug 17, 2013 | 07:01 PM
mrcool007's Avatar
mrcool007
that sounds like your engine values are lose and need tightening up due to high mileage use, these get lose over time due to wear. may also possibly need replacement. A mechanic can easily fix this issue.
Old Aug 18, 2013 | 02:25 AM
JSolo's Avatar
JSolo
Just say no!!!!!
^^Are you referring to valve lash? (gap between the valve stem & cams)?
Old Aug 18, 2013 | 05:06 AM
unknowndesi
I think that's what mrvool007 is talking about. Isn't the vvel system significantly different than a regular cam and valve setup? I'm beginning to think its a timing chain issue because it's consistent with engine speed and appears to be coming from the front of the engine. I just got back from work I'll check it out in the morning with a stethoscope, I'll also check for deposits on the oil by taking the oil pan off if I can confirm the noise is coming from some where in the timing chain area. Watch this turn into a build thread hahha
Old Aug 18, 2013 | 10:57 PM
unknowndesi
Problem solved!!! I took a mechanics stethoscope and pin pointed the noise to the tensioner pulley. I took the serpentine belt off and spun the bearing with my finger and man was it loud. I guess I'll be ordering one in.
Old Aug 19, 2013 | 05:04 PM
SharpByCoop's Avatar
SharpByCoop
Good to know it's this 'simple'. Relatively.
Cmonnnnnnnnnn! Valve ticking? Replace the valves? Easily?
Not, not, and NOT!
Coop
Old Aug 20, 2013 | 01:51 AM
unknowndesi
Old Aug 20, 2013 | 03:18 PM
twin_snails's Avatar
twin_snails
Thanks for sharing with every one and I'm glad to know it was a simple fix and not something more serious.
xxg00w0
Intake and Exhaust
42
Mar 18, 2021 07:44 PM
Slapshot1
Sep 27, 2015 08:40 AM
dedmanchan
Sep 24, 2015 11:25 PM
