Coolant Issue
Old May 21, 2013 | 09:32 AM
fgxmfmq's Avatar
fgxmfmq
Coolant Issue
I have a 2008 G37 s, and noticed some greenish crust on the upper hose in the area where it mates to the engine. I purchased a new hose, and about ready to change it, my question is does it have to be bled if just the upper hose is to be changed? I assume not much air would get it or much coolant loss. I dont want to make a mistake.
Old May 21, 2013 | 09:42 AM
08skyline's Avatar
08skyline
it wouldn't hurt i would change the clamp also as they get weak over time.
Old May 21, 2013 | 09:44 AM
JSolo's Avatar
JSolo
Just say no!!!!!
In a word, yes, you will get air into the system by swapping out the hose(s).
Get one of those lisle spill free funnels -
Amazon.com: Lisle 24680 Spill-free Funnel: Automotive Amazon.com: Lisle 24680 Spill-free Funnel: Automotive
My own recommendation is since you'll already be doing half the job, do it properly and thoroughly. Replace the other hose, radiator cap, and depending on miles, maybe even the thermostat. When you drop the lower hose, the radiator will also drain. Otherwise, it's somewhat of a half @ssed job. Not a bad idea to change the drive belt out at the same time either.
Old May 21, 2013 | 09:45 AM
Is the hose itself actually leaking or is the clamp simply loose or out of position?
And yes, you'll lose a significant amount of coolant changing out the upper hose and it needs to be replaced and the system bled of air.
Old May 21, 2013 | 11:36 AM
fgxmfmq's Avatar
fgxmfmq
what is the best procedure to bleed the system?
Old May 21, 2013 | 11:53 AM
JSolo's Avatar
JSolo
Just say no!!!!!
^^You'll find the answer here
D.I.Y. Installations/Modifications - MyG37
On the right hand side, "search this forum", type "cooling", 12th thread down.
vamarris
Dec 9, 2018 11:10 AM
Rybitron
Nov 18, 2015 03:11 PM
si_driver
Oct 1, 2015 09:53 AM
djdiskino
Sep 29, 2015 07:18 PM
MrRiv
Sep 29, 2015 04:59 PM
