Review Motordyne M370 & RJM pedal.
Old May 16, 2013 | 09:12 PM
Brainchild's Avatar
Brainchild
The MD top plate has some sharp edges! Looks like it's starting to [barely] cut into the plastic on the intake manifold. Not that it matters...
Old May 17, 2013 | 03:39 AM
venzz's Avatar
venzz
from what I understand, the Motordyne m370 is just a intake manifold from the vq35hr engine. The VQ37 is the updated version of vq35, any idea why nissan changed to a lesser performance design? there has to be a reason that nissan didnt use the intake manifold right?
Old May 21, 2013 | 01:57 PM
NJ Torque's Avatar
NJ Torque
Anyone else have insight on this?
Old May 22, 2013 | 08:26 PM
IAmYourPal's Avatar
IAmYourPal
In for updates also interested.
Old May 22, 2013 | 09:08 PM
From the horse's mouth (a phone conversation about the subject with Tony): Yes, the M370 is a modified HR intake manifold. However it flows significantly better than the stock VHR intake manifold. As shown by flow testing and HP/TQ gains. So then why did Nissan change it? Who the hell knows. I don't but I wonder as well. Does it really matter if it works better?
Old Jun 3, 2013 | 07:57 PM
gizmo0034's Avatar
gizmo0034
took some time to go through my engine bay this afternoon and wanted to share some of the rubbing with the cusco bar installed. present on both top and bottom, so the fitment is pretty tight. i did just take out the center rubber washer on the engine cover which seemed to help, highly recommended. i apologize for the poorly lit pictures.
rubbing looks like bird turd
center washer removed
Old Sep 9, 2013 | 02:19 PM
lightlypurified's Avatar
lightlypurified
any noise diffrence when this contraption was intalled?
Old Sep 23, 2013 | 10:03 PM
GoFightNguyen's Avatar
GoFightNguyen
Because Racecar
Yes, my current setup is the M370, K&N inakes, and Fast Intentions HFC's and CB exhaust. I installed this today and noticed the tone is louder and maybe a little deeper. Unsurprisingly, it hasn't done anything to add/decrease rasp/hiss, which I like anyways.
I'm curious if anyone is a little bit nervous about just sticking their MAP sensor from the old manifold into a rubber vac line. It doesn't look very secure at all, so I ziptied it in. That's not really secure, it's just there to keep it from bouncing around if it DOES fall out. Does anyone have a fix for this? I can post pics if that would help.
Here's a pic of mine installed, the blue collection of zipties in the upper left corner is my attempt at securing it.
Old Oct 1, 2013 | 09:39 PM
G370Z's Avatar
G370Z
I never had a problem with my MAP sensor coming loose, even under continuous abuse on the street/track. I had the same feeling about it when re-connecting the sensor but I guess it's more secure than it looks. Just drive and enjoy the manifold until you have a problem with it.
Old Nov 1, 2013 | 09:20 PM
lightlypurified
installing this was a pain in the butt does anybody know if this will effect me once i smog my car?
Old Nov 1, 2013 | 09:29 PM
GoFightNguyen
Because Racecar
I thought it was pretty easy. It won't bother your inspection.
Old Nov 1, 2013 | 09:38 PM
saparda's Avatar
saparda
not sure if this is the right place to post this but did anyone try the this intake manifold with forced induction, planning on getting a supercharger soon and not sure if i should put my stock manifold back or keep the Motordyne?
Old Nov 1, 2013 | 09:48 PM
GoFightNguyen
Because Racecar
The manifold is turbo and super compatible.
Old Nov 9, 2013 | 08:33 PM
  #29
chucky's Avatar
chucky
M370 dyno
are there any dyno's for the G with mods?
Old May 4, 2014 | 01:54 AM
  #30
ash_raff88's Avatar
ash_raff88
hey guys sorry to sidetrack abit, but i have one for sale if anyone is interested. Bought for my ride but as it is a 250GT/G25 it wont fit so i'm stuck with it. Brand new set from conceptz letting go cheap if anyone is interested. You can contact me at ash_raff88@hotmail.com if anyone is interested.
