Help Any idea what this plug is for ?
Old May 4, 2013 | 07:28 PM
venzz's Avatar
venzz
I noticed this plug just hanging out there between the front radiator and the crash guard. Any idea what this is used for?
Old May 4, 2013 | 07:32 PM
Modme's Avatar
Modme
Looks like it could be the outside temperature sensor harness. The temperature sensor is usually secured to the metal bracket on the top of your picture.
Old May 4, 2013 | 07:35 PM
venzz's Avatar
venzz
wait, does that mean I lost the outside temperature sensor? Dash temperature seems to be accurate tho...
Old May 4, 2013 | 07:39 PM
Modme's Avatar
Modme
Upon closer exam, it's not the temperature sensor. You must've disconnected it while installing your intake. You cant remember what you disconnected?
Old May 4, 2013 | 07:46 PM
Modme's Avatar
Modme
Ohhh, i know what it is! Must be the washer fluid pump. You disconnected it while installing the intake. Forgot to plug it into the new washer.
Old May 4, 2013 | 07:50 PM
venzz's Avatar
venzz
It was actually disconnected ages ago when i first had my intake installed and i wasnt the one who installed it.
As for the washer fluid pump, mine still work with this plug in tho.
Old May 4, 2013 | 07:51 PM
venzz's Avatar
venzz
Could it be the plug for the speed sensor ? Optional on some g37s?
Old May 4, 2013 | 07:55 PM
Modme's Avatar
Modme
Does the car have tech package? What year is it?
Old May 4, 2013 | 08:03 PM
venzz's Avatar
venzz
2010. I dont have the adaptive cruise control package.
Old May 4, 2013 | 08:13 PM
Modme's Avatar
Modme
Check on the back of your crash bar. The temperature sensor is attached to the back of the crash bar on the passenger side. I'm still suspicious that this is the temp sensor.
Old May 4, 2013 | 10:15 PM
Doubleminded's Avatar
Doubleminded
Let me guess, you don't have fog lights? There is your answer.
Old May 4, 2013 | 10:19 PM
TVPostSound's Avatar
TVPostSound
ICC wiring, not needed as you dont have the tech package.
Old Jun 9, 2020 | 08:29 PM
dirtnapper56's Avatar
dirtnapper56
Hey man that looks like it could be a fan controller harness or even maybe an intake sensor harness for the maf. If not that check your cam sensors. If not that check all your headlights and even the horn connector.
Old Jun 9, 2020 | 09:33 PM
ILM-NC G37S's Avatar
ILM-NC G37S
Seven years later I doubt it is relevant anymore...
stm37s
The M - Spot
14
Oct 23, 2015 01:56 AM
butwhatuptho
Oct 4, 2015 07:51 PM
parkern
Oct 1, 2015 10:15 PM
Chappedj
Sep 28, 2015 03:20 PM
mikysee
Sep 28, 2015 11:18 AM
