Got a feeling my 08 AT has a 3.357 diff
Old Apr 5, 2013 | 08:03 AM
G37Sam's Avatar
G37Sam
Fellow AT 08'ers,
At what road speeds do you redline 1st, 2nd and 3rd? (Assuming a redline of 7500 rpm). And how fast are you going at 3k rpm in 5th?
I have a feeling my GCC Spec 08 has a 3.357 rear end rather than a 3.692.
Thanks for your help.
Old Apr 5, 2013 | 10:12 AM
indyn's Avatar
indyn
hey Sam
since you swapped a RB25 gearbox, wouldn't that affect your overall gear ratios and resulting in different speeds through each gear?
Did you have the same redline speed before the swap?
Old Apr 5, 2013 | 10:23 AM
G37Sam's Avatar
G37Sam
You are correct Indyn. I want to compare peoples numbers to mine before I did the swap.
My tuner who has an RB30'd 350Z (RB25 Tranny + 3.5 diff ratio) says that my gears are much taller than on his Z. That is why I am suspecting my diff is not a 3.692.
Old Apr 5, 2013 | 11:07 AM
Can'tGme's Avatar
Can'tGme
Sam - There is a way you can determine your gear ratio by jacking the rear of the car up and counting the rotations of the driveshaft as you turn one of the rear wheels. I forgot exactly how you do it but I'm sure Google would help lol.
Old Apr 5, 2013 | 11:12 AM
TVPostSound's Avatar
TVPostSound
Your car came stock with an AT, right?
It's a 3.357.
Stock MTs came with a 3.692.
According to the 2008 FSM.
Old Apr 5, 2013 | 11:16 AM
TVPostSound
Correction, 5AT in 2008 came with 3.692. There was no 3.357 option.
Hmmmm??
Old Apr 5, 2013 | 11:18 AM
TVPostSound
Put it on a hoist, mark the driveshaft at 6 o'clock, ,ark the ale shaft at 6 o'clock, turn the driveshaft, and count the turns of the axle shaft.
Old Apr 9, 2013 | 02:54 AM
G37Sam's Avatar
G37Sam
I tried that and it wasn't very successful. It's not easy to turn the driveshaft LOL. And when tried turning one wheel, the other one also started turning (at least I got an LSD though )
Can anyone reply to my first question though?
Old Apr 9, 2013 | 09:11 AM
SharpByCoop's Avatar
SharpByCoop
Sam, when I watch my drag vid below, I shift TO 4th JUST after the eighth mile markers (1:38" on the vid). I'm going exactly 99mph at the eighth, and I'm shifting at 8000rpm.
3150 is my current 80 MPH RPM.
How are you measuring speed? Is your speedo accurate?
Coop
Old Apr 10, 2013 | 12:07 PM
indyn's Avatar
indyn
70 km/h in 2nd at 5k rpm.
100 km/h in 3rd at 5k rpm.
my km/h might be off little bit as my speedo is in miles.
Old Apr 10, 2013 | 02:50 PM
bluedevils95's Avatar
bluedevils95
2008 final drive is 3.692
Old Apr 12, 2013 | 05:38 PM
G37Sam's Avatar
G37Sam
Confirmed via GPS that my speedo is working fine. Yet every gear ratio calculator indicates that there is no way I'm on a 3.69 ratio. There must be some sort of hidden coupler somewhere in my drivetrain lol
Old May 28, 2013 | 04:40 AM
G37Sam's Avatar
G37Sam
I finally pulled my OEM Ring & Pinion out. My fellow 5 speeders, I got some bad news for you:
This was pulled out of my OEM diff. It shows that the Ring has 47 teeth, and the Pinion has 14 teeth. If you do the math, that's a ratio of 3.357:1. Every online resource I came across showed 3.69:1 just like the MT but that is clearly not the case. I double checked with Nissan's technical department here and they have confirmed that it's a 3.357:1 not 3.69:1.
Luckily, this bad boy is going to replace it
Old May 28, 2013 | 05:17 AM
1G372nv's Avatar
1G372nv
Oh no it cant be! Thanks for clearing that up Sam.
Old May 28, 2013 | 09:06 AM
SharpByCoop
OK! Well, it all makes sense even if the specs don't. At least you WILL get the increase you wish.
IS that the 4.08 set in the second photo? And.... what are you learning about jamming that in there.
Coop
