Gears Scratch/Grind When Shifting Gears
Old 12-05-2012, 12:17 AM
BTK
BTK's Avatar
My '09 G37S manual transmission is scratching/grinding when I shift gears, mainly 2nd, 3rd, and 5th. The car has 31k miles. Its under the Certified Pre Owned warranty which I I'm pretty sure covers the transmission. Will they give me a new transmission just because the gears scratch? How should I approach the service people?
Old 12-05-2012, 02:08 AM
JSolo
Just say no!!!!!
JSolo's Avatar
Assuming you got a good firm pedal and clutch is disengaging properly, it sounds like a synco issue. If your warranty covers the trans faults, you should be covered.
At 31K syncro's should not be worn out under normal usage.
Old 12-05-2012, 11:29 AM
TVPostSound
TVPostSound's Avatar
Especially 3 different gears!!
I would suspect clutch, or driving experience (lack of).
Old 12-05-2012, 01:28 PM
Sython
Sython's Avatar
I agree. Sounds like synchros are bad. Take the car in and let them look at the gearbox before you lose a gear!
Old 12-05-2012, 06:50 PM
tyler20c
tyler20c's Avatar
Mine did the same thing but just in 3rd and 5th. Replaced transmission under warranty. I guarantee you will end up with a new tranny.
Old 12-05-2012, 10:47 PM
unknowndesi
unknowndesi's Avatar
Mine does that some times in the cold while going into reverse dealer said its a wear and tear item and will not be covered under warranty... Man I'm so pissed right now
Old 12-05-2012, 11:41 PM
john91
john91's Avatar
Does that to me, sometimes going to 5th, not always...
Old 12-05-2012, 11:46 PM
Tonyq
Tonyq's Avatar
me too when its cold... 63k miles
Old 01-20-2013, 05:39 PM
jon23
jon23's Avatar
Where you able to resolve this? What did the dealer say?
Old 01-22-2013, 11:37 AM
jjasonSU
jjasonSU's Avatar
Mine did this at 19k, I took it in and received a new
Transmission
Old 01-22-2013, 02:24 PM
JSolo
Just say no!!!!!
JSolo's Avatar
Lots of reports of 6mt's getting replaced recently. If it's such a robust and bulletproof trans, why such early failures. I can understand replacing a trans at 100K or 150K, but not under 40K.
Old 01-22-2013, 02:38 PM
eksigned
eksigned's Avatar
so difficult -- because all observations are subjective. in all honesty, I had the same concerns about my transmission in going to 2nd, 3rd, and 5th. my dealer took it so seriously that they ended up removing the tranny, opening and examining all the synchros. while I appreciated their "go get it" approach...it turned out that my gearbox was just fine. our boxes are just...rough around the edges.
Old 01-25-2013, 12:38 PM
kstampy
kstampy's Avatar
I had a grind going in to 6th and was replaced by warranty. 45k miles.
Old 01-25-2013, 06:10 PM
socialconflicts
socialconflicts's Avatar
yea for me it seems the same. 2/3/5 im almost left with shift a bit more firm and not as fast as i would want to engage the gear in. i have taken it to two different dealers, both say that the gears are fine.. so idk what else to belief but just assume they are.
my in law has an 03 g coupe and his shifts much smoother he says (he tested out the gearbox on my car)
but from what i have heard from dealers/people in the forum is that our tranny is just rough..
Old 03-04-2013, 11:17 PM
Glenn2008
Glenn2008's Avatar
I see that several G37 owner's have had gear grind. I have noticed it in my '08 going into 5th gear. This only happens when it's cold, after it warms up it's smooth. I have an appointment with Infiniti tomorrow. The service tech said that it's probably the cluitch, but I believe it's the 5th gear syncro. IMO, if it were the clutch, I would have the problem in more than just the one gear and the grind wouldn't go away when it warmed up. Appreciate any feedback.
Quick Reply: Gears Scratch/Grind When Shifting Gears
