G37 engine noise under hard acceleration
Old Sep 23, 2012 | 10:01 PM
G37beijing's Avatar
G37beijing
I started hearing this strange metallic clicking/clacking noise for about a month. The recording was taken with an iPhone about a foot away from the NAVI screen. It happens only under hard acceleration when RPM is over 5,000. It most often happens when accelerating with WOT from a speed of around 80km/h. My car is stock 2009 with 70,000km and I've been using premium gas. The car otherwise drives OK.
Anybody had similar problems?
File Type: zip
Old Sep 23, 2012 | 10:09 PM
LexiG37's Avatar
LexiG37
Are you using a good quality synthetic? Conventional oil will shear down under extreme load leading to metal-to-metal contact. BTW, couldn't open the .zip file
codeflux's Avatar
codeflux
20 Year Member
mine does that too, i've searched these forums and folks say it's VVEL kicking in. so, it's normal.
Old Sep 23, 2012 | 10:27 PM
G37beijing's Avatar
G37beijing
I cannot seem to upload the ZIP file properly. The file is OK after WinZip compression. Upload seems OK too. But when I downloaded it and try to unzip it, WinZip says "File is corrupt". This seems to be a problem of the site.
A bit tricky to play the audio. Please use WinRAR to unzip. Then play it. Winzip does not work here.
Old Sep 24, 2012 | 12:17 AM
JSolo's Avatar
JSolo
Just say no!!!!!
The file is not a zip, it's actually an mp3.
Hard to tell what it is, almost sounds like a rattle.. Maybe heat shield rattle? If you have access to a lift, see if anything is loose. If not, jackstands/ramps and start tapping around.
Old Sep 24, 2012 | 12:21 AM
speedracer g37's Avatar
speedracer g37
no rattling is normal under any kind of acceleration. rattling is metal on metal without lubrication.
Skyaddict
13
Nov 8, 2018 07:14 PM
b2autodesigns
Brakes/Suspension
128
Mar 24, 2018 07:44 PM
Thedbarz
33
Feb 9, 2016 12:05 AM
Digilog
Aug 17, 2015 03:54 PM
SS2006
Aug 11, 2015 10:24 PM
