Rough morning startup
Old Aug 15, 2012 | 01:13 PM
apexi957's Avatar
apexi957
Hey guys i had a question for y'all. The past 2 mornings the car has been having long and rough start ups. Any input? Battery tested okay and i'm guessing it might be the fuel pump?
Old Aug 15, 2012 | 01:38 PM
jon23's Avatar
jon23
It could be low pressure in the fuel lines, which would probably lead as you had expected, to a defective fuel pump. Does it stall sometimes, or smell like gas?
Old Aug 15, 2012 | 01:52 PM
Rad_Slinger's Avatar
Rad_Slinger
Dirty MAF?
Dirty throttle bodies?
Dirty/clogged fuel filter?
Bunch of things could be the culprit
Old Aug 15, 2012 | 01:53 PM
joshk's Avatar
joshk
yea way too vague to pin point the problem
Old Aug 15, 2012 | 01:58 PM
DashKid's Avatar
DashKid
Best thing to do is probably record a vid and upload it.
Old Aug 15, 2012 | 02:50 PM
apexi957's Avatar
apexi957
Will do. I'll check the battery one more time, but as for now i'm waiting for the oil to cool down.
Old Aug 16, 2012 | 07:41 AM
jmueller's Avatar
jmueller
Have you tried getting the acc on before starting the car? Don't put your foot on the brake or clutch (depending auto or manual) press the start button twice, after the fuel pump runs for 2-3 seconds (yes you can hear some little wizard working in the engine) then start the car. I don't have your issue, but it significantly improves cold starts regardless.
Old Aug 17, 2012 | 12:11 AM
adam's Avatar
adam
Isn't it under warranty or have you already went through the limit?
I would second the opinion of cleaning the throttle bodies. After I cleaned mine the car ran weird for 15 minutes and I thought I screwed it up but after that it's felt smoother.
Victory
17
Oct 27, 2022 03:45 PM
fuzzed
Aug 21, 2020 09:35 AM
vamarris
Dec 9, 2018 11:10 AM
4DRZ
Nov 7, 2015 08:32 PM
dedmanchan
Sep 24, 2015 11:25 PM
