Push-button Starting Problem
Old Sep 7, 2012 | 11:18 PM
ricbel's Avatar
ricbel
I think it was a 14mm wrench, I did it with a 9/16th" since I didn't have 14mm. You just gotta loosen that nut in the back and unplug the connector to the switch, and twist the switch by hand. Retighten the nut and you're done. Becareful how far up you twist it because you can cause your clutch to not be able to fully disengage.
Old Oct 28, 2012 | 07:18 PM
duck31905's Avatar
duck31905
Well adjusting the switch didn't fix anything for me. Anyone else have any other ideas?
Old Jun 12, 2013 | 08:03 AM
x37sx's Avatar
x37sx
starting problems
My battery keeps draining mysteriously. Always put it on the charger bought a new battery but i tested both and they are both good. so i started the car daily for two days in a row no problem and i figured if i did it daily the battery would keep a charge. (maybe there's a drain on the battery somewhere), i missed a day and the following day the i go and push the button and just hear the click click. all the dash and stereo lights illuminate. i tried to jump it and i tried to recharge the battery but it still just clicks. will not start at all. any thoughts?? maybe that clutch switch thing gone out completly? the dealership just replaced the bcm a few months ago havent driven the car much since then. dont know how to adjust that switch if id have to..
Amaadkhan2k
Oct 4, 2024 01:20 PM
reachout
General Tech Questions
38
Jun 27, 2020 12:35 AM
SuicidalG37SGuy
Sep 10, 2015 06:01 AM
ZachThomas
Sep 3, 2015 01:40 PM
