Help Clutch problem?? :-(
Old Jun 17, 2012 | 04:19 PM
G+36+1='s Avatar
G+36+1=
Hey guys, I have a question and I'm just looking for some input. This Friday I was driving my G (6MT, 49,871 miles) home from work and all of a sudden I noticed the clutch pedal would not come back from the floor after being engaged. I had to put my foot underneath it to pull it back up. As I drove and got closer and closer home, it got worse and I literally had to stand on the clutch to get the car in gear and shift thru the gears. Then all of a sudden at a stop light when I tried to pull off, I could barely get the car in 1st gear to pull off, so I decided to pull off the road into a nearby apartment complex because I felt like the car wasn't gonna make it. Sure enough once I stopped I could not get the car into any gear other than neutral and this is with the clutch pushed to the floor. Ultimately, I had to have the car towed to the nearest Infiniti dealership that evening and the following morning (Saturday) I called the dealership just so I can actually talk to a service rep and explain exactly what was going on. The first thing the guy said is he thinks it may be the clutch gone bad but he could be wrong and to keep my fingers crossed. I asked him how could a clutch just go bad immediately like that with no warning. It's was always solid. It never slipped or gave any indications at all that it was going bad and yes I know how to properly drive a manual, I'm 28 years old and I've been driving a manual since I learned how to drive at the age of 16. My last 3 vehicles were 6MT. Anyway, I won't know until tomorrow when the dealership opens what the verdict is, but I hope it's something that will be covered by the powertrain warranty and not the clutch that I know will not be covered. Has anyone else had the same situation? Could it be the slave cylinder? Any help will be greatly appreciated Thanks!
Old Jun 17, 2012 | 04:23 PM
Rad_Slinger's Avatar
Rad_Slinger
There was a thread a few weeks ago about the same exact issue.
I think the final descision on what was wrong was the clutch cylinder was bad.
Old Jun 17, 2012 | 05:49 PM
Clutch master cylinder or possibly slave cylinder. Either will be covered by warranty.
Old Jun 17, 2012 | 08:20 PM
G+36+1='s Avatar
G+36+1=
Thanks you guys have already made me feel a little bit better about the situation. I will see fo sho tomorrow.
Old Jun 17, 2012 | 09:19 PM
SoulSeeker's Avatar
SoulSeeker
My master clutch cylinder went and did that exact same thing ,my car had 57,000 miles on it
Old Jun 17, 2012 | 11:31 PM
V36Skyline's Avatar
V36Skyline
I had a similar problem, all fixed now from replacing the master clutch cylinder so i hope all goes well and you get your G back to you asap.
Old Jun 18, 2012 | 12:42 PM
JSolo's Avatar
JSolo
Just say no!!!!!
Originally Posted by Mattster
I think the final descision on what was wrong was the clutch selenoid was bad.
What is a clutch solenoid?
Old Jun 18, 2012 | 12:54 PM
Rad_Slinger
Meant cylinder. Selenoid was the wrong term. Sry
Old Jun 18, 2012 | 05:38 PM
cruzmisl's Avatar
cruzmisl
Drivetrain Warranty?
Old Jun 18, 2012 | 05:46 PM
That's the one.
Old Jun 24, 2012 | 11:01 AM
G+36+1='s Avatar
G+36+1=
Ok well I have the car back now and it was the slave cylinder failing. Wasn't covered under drivetrain warranty I was beyond pissed but around $700 later, im back shifting again. Thanks guys for all of your input.
Old Jun 24, 2012 | 03:22 PM
Sunny G's Avatar
Sunny G
It should be covered under your warranty other I think you got screwed by the dealership
Old Jun 25, 2012 | 12:44 AM
JSolo's Avatar
JSolo
Just say no!!!!!
I agree. How is a clutch slave cylinder not part of the powertrain/transmission system. It's definitely not a wear item.
Old Jun 25, 2012 | 08:57 AM
The clutch friction surface or flywheel friction surface are wear items and may not be covered by power train warranty. The concentric slave cylinder is most definitely not a wear item and should be covered by a power train warranty. Unless you just have the $700 to burn, I'd suggest speaking to your dealership service manager about this. If he doesn't agree, then speak to the general manager. If he doesn't agree let him know that you will cal Infiniti Consumer Affairs and ask them about it. That may do the trick. If not, cal them and explain that you were required to pay for a repair to a CSC on a vehicle that is still under warranty and see what they say.
Old Jun 25, 2012 | 10:58 AM
DeamonG37s's Avatar
DeamonG37s
Agree with bb that's warrenty
stevo4756
Oct 9, 2015 01:54 AM
butwhatuptho
Oct 4, 2015 07:51 PM
MrRiv
Sep 29, 2015 04:59 PM
k19g37x
Sep 29, 2015 02:46 PM
r0cketm0nkey
Sep 27, 2015 01:34 PM
