car is shaking and feeling like it gonna stall anyone know?
Old May 13, 2012 | 02:36 PM
Skilled's Avatar
Skilled
i start driving and the car is bobbing like it want to stall on me, if i hit the gas pedal down the car start to shake and feel like engine want to stop i try to push more gas and engine is shaking real rough then i start to smell something like something burning... doesn't anyone know what this could be? or has anyone had this problem with the VQ37?
Old May 13, 2012 | 02:39 PM
myk1013's Avatar
myk1013
Have you installed something recently?
Check your MAF sensors if they're on correctly.
Old May 13, 2012 | 02:43 PM
Skilled's Avatar
Skilled
do you mean the MAF on the Intake system? i change out my system to a INjen CAI been running fine for couple month. it was fine last night press pedal and the car was fast and smooth. this morning jump in the car and it start shaking on me and feel like it want to stall..
Old May 13, 2012 | 02:48 PM
myk1013's Avatar
myk1013
Yes, the MAF sensors...check if they're loose or something.
When my car was broken into, one of my MAF sensors was disconnected. I didn't know and I drove the car a good 40 feet. It sputtered the whole time, almost stalling.
Old May 13, 2012 | 02:59 PM
Skilled's Avatar
Skilled
i just when to check it the connection is good and the its not loose in any sore of way for it to fall off... you think i should unbolt it and check the sensor and rebolt it?
Old May 13, 2012 | 03:37 PM
myk1013's Avatar
myk1013
You can try that.... see if there's anything wrong with the sensors.
Other than that, I don't know what's wrong with it. Good luck.
Old May 14, 2012 | 06:21 AM
G37Sam's Avatar
G37Sam
If this occurs in Neutral, then I'd assume its your MAF sensors as well. Basically the engine is receiving a lot less air than being read. The smell could possibly be due to the very rich mix
superjoey
31
Mar 22, 2023 11:56 PM
JoshB
Oct 15, 2015 03:08 PM
mauiwowie
Aug 16, 2015 06:01 PM
MeatySock
Aug 14, 2015 08:25 AM
