D vs. DS vs. M
Old May 1, 2012 | 10:12 AM
2012G37's Avatar
2012G37
D vs. DS vs. M
Sorry if this is a repeat, but I couldn't find the answer I wanted.
So coming from a 09 max, D mode was the quickiest. Can someone give me a breakdown of the xS. Drive modes?
Old May 1, 2012 | 10:45 AM
Tazicon's Avatar
Tazicon
D is for normal, most fuel effiencent driving. DS is for sport driving, M is manual, you shift the car, note this is not like manually shifting other cars. It will bounce off the rev limiter if you forget you are in the manual mode. It will not shift up untill you tell it to with either the gear shifter or the paddles if you have them. If you are in D mode you can manually shift the car then it will go back to D mode. If you are in DS and shift manually it will stay there till you move the shifter back to D.
Old May 1, 2012 | 11:02 AM
2012G37's Avatar
2012G37
Ok, which gives you a better 0 to 60. And 1/4 mile
Old May 1, 2012 | 11:34 AM
rpm&my_G35's Avatar
rpm&my_G35
^ ds
Old May 1, 2012 | 12:23 PM
Tazicon's Avatar
Tazicon
DS or if you are good at shifting the 7AT do it in Manual for better times. In my Z I run in manual only. In the G I switch around.
Old May 1, 2012 | 02:27 PM
2012G37's Avatar
2012G37
Ok. Thanks for the info. Now that sounds better. Not to down play the max, its weird D mode is quicker than Ds. I love this G.
Old May 1, 2012 | 02:37 PM
kanariya's Avatar
kanariya
there were members here who did 1/4 miles and result D was faster than DS.
Old May 1, 2012 | 04:19 PM
Tazicon's Avatar
Tazicon
I find that hard to believe seeing how my car shifts in DS and in D. D doesn't get you into the power band of the car before shifting.
Old May 1, 2012 | 04:24 PM
mahonesbones's Avatar
mahonesbones
ds and d mode will yield the same results in the 1/4-your hand will not be faster than the computer so if u want the best number dont waste your time in manual mode-trust me ive done about 100 runs if not more at the track with the g
Old May 1, 2012 | 04:35 PM
kanariya's Avatar
kanariya
I'd love to dig out the thread but I don't know where to find it anymore.
It was on this forum.
Old May 1, 2012 | 06:43 PM
ashmostro's Avatar
ashmostro
This seems weird to me.
At WOT, my car shifts at redline in either D or DS. I think DS is only beneficial at throttle openings less than WOT.
I also don't see how DS would be slower at WOT than D... but maybe it's because the more aggressive logic accidentally lets the engine bounce off the rev limiter before shifting? I haven't had this happen personally, though. I'll stick with my story that they are meaningless comparisons at WOT.
M is definitely more tricky to get right than either automatic mode if you're just dragging. M is really meant for controlling your gearing in spirited canyon carving, not for fastest straight line acceleration. That's just not how it should be used.
Old May 1, 2012 | 10:08 PM
trcb777's Avatar
trcb777
^ agree 100%
Old May 4, 2012 | 12:18 AM
pdpMIATA's Avatar
pdpMIATA
Last time i read, DS was meant to keep you up in higher gears without the car shifting so early, giving you that "sporty" feel as if you're controlling your rpms.
If you floor it, D or DS, im pretty sure it does the same exact job. I doubt the computer would favor which to work faster for.
joebrez
Sep 22, 2015 11:54 AM
rafirat
Sep 23, 2008 11:14 AM
Railgunner
The M - Spot
Sep 27, 2006 01:55 PM
