camshaft installation?
Old Apr 16, 2012 | 03:16 PM
indyn's Avatar
indyn
can someone recommend garage, tuner who can install camshafts and have done it with VQ engines in the tri-state area?
Old Apr 16, 2012 | 03:21 PM
37hevn's Avatar
37hevn
did you get an aftermarket camshaft? where/what brand?
Old Apr 16, 2012 | 03:57 PM
TheLocNar's Avatar
TheLocNar
My guess is the JUN exhaust camshafts...
JUN exhaust cam shaft finally arrived - Nissan 370Z Forum
OP, good luck finding someone... it'll be at least $1,000 for install alone. Probably closer to $2k.
Old Apr 16, 2012 | 05:45 PM
indyn's Avatar
indyn
oh good, you been following that. Yup, apparently it won't be easy with our heads, no wonder some ppl are looking into switching to VQ35HR heads.
Old Apr 16, 2012 | 06:30 PM
Tazicon's Avatar
Tazicon
It seems like a lot of money for 10 to 15 whp (2k to 3k). I am watching that thread none the less.
Old Apr 16, 2012 | 09:22 PM
SkylineAWD's Avatar
SkylineAWD
That's a lot of $$$ good luck with the build if you're going this route.
Old Apr 16, 2012 | 09:33 PM
37hevn's Avatar
37hevn
i just read the entire thread, it sounds like a massive group of people that dont know what anything cost or just what is going on. i worked at a shop and they roughly charged 800-1200 for cam install on vettes. im not sure i want to be the first few that does a cam job on a daily driver either...its hard enough trying to find a shop that knows how to tune uprev on an na car. if they claimm 15-20 it will be 10-15. idk how much the parts cost but total after tuning sounds like a 2500 bill at least. thats about $165 per hp. i guess if its a peeing contest go for it but you can get a loan and that 2500 cash you have will go far on payments to get a supercharger that is about $30-40 a hp. just saying
Old Apr 16, 2012 | 09:51 PM
TheLocNar's Avatar
TheLocNar
Yeah, doesn't seem worth it at all... if you're staying NA, this would be money wasted. But if you're going FI, I could see this being done.
I won't be doing this mod, but it's interesting seeing what others are up to.
Old Apr 16, 2012 | 11:22 PM
TVPostSound's Avatar
TVPostSound
Read the dyno small print, that was with Carillo pistons, and hotter injectors!!
Old Apr 16, 2012 | 11:39 PM
indyn's Avatar
indyn
just looking into this guys, haven't got the cams yet;
granted price paid for hp is higher than going with FI, but when was FI without issues !!!
There's a reason some ppl tend to stick with NA; bolt ons will only give you so much so you explore other options.
About installation, quotes I got were from 1k to 2k; 2k is when the installer wants to drop the engine and is meticulous. Just like when installing twin turbo kits, some garages drop the engine and some don't. Both quotes from reputable shops.
Anyways, there are other brand camshafts besides JUN that will be coming out in near future, testing is going on and positive gains with proper tuning. No one's going to make these if the end result is too expensive. This will help not only NA but also FI.
Mind you, gains are across the power band not just at the Peak.
Old Apr 17, 2012 | 12:40 AM
37hevn's Avatar
37hevn
well if your too that point get your heads ported while they are in there. its incredibly easy. a good diy or if its already apart prolly just an extra 400 to port it and that will be 10 hp.
if youre staying na and dont care about mpg then get bigger injectors, rear end upgrade. nitrous is always a steal of a deal at the wheel. if you get at 50 shot you wont have more than 700-800 and it wont hurt your stock setup unless you abuse it and race every neon that wants to. lighter rear wheels and tires. its all good fun
Old Apr 17, 2012 | 08:45 AM
TeRRoRiFiC35's Avatar
TeRRoRiFiC35
Best recommendation is to find a shop that does a lot of work on 350z's, 370z's, and GTR's which there are few in the NYC/NJ area. The two that come to mind are JDS Motoring and Akuma Motorsports. Akuma I know does a lot of work on the GTR's.
Old Apr 18, 2012 | 01:52 PM
indyn's Avatar
indyn
porting, headwork, etc will cost more than replacing camshafts and doing headwork hasn't done much in the VQ35 engines.
thanks buddy.
Old Jun 2, 2012 | 10:34 PM
kpjc4eva's Avatar
kpjc4eva
darton sleeves east coast does these installs. how i know? cuz im getting my block built there.
staaksondeck
Mar 14, 2016 11:15 AM
Thedbarz
33
Feb 9, 2016 12:05 AM
moy92
Aug 20, 2015 08:43 PM
moy92
Aug 19, 2015 05:30 PM
cparise
Aug 19, 2015 01:51 PM
