Help Stillen Supercharger kit install HELP!
Old Feb 20, 2012 | 05:28 PM
  #31
Tazicon's Avatar
Tazicon
Wow it is kind of hard to figure out what you are saying at times. So you said you put the stock fuel pump back on and the car fired up?
Old Feb 20, 2012 | 05:48 PM
  #32
Fezzik's Avatar
Fezzik
I think you figured out your problem.
Old Feb 20, 2012 | 06:41 PM
  #33
martyg's Avatar
martyg
So it looks like I made a very dumb mistake since I isolated it to all injectors not sending fuel. The fuel rail connector wasn't hooked up. I am so mad for such simple mistake I made. Thanks for everyone's input and help.
Old Feb 20, 2012 | 06:43 PM
  #34
Weiboy718's Avatar
Weiboy718
so did it finally fired up? i was gonna ask you did you plug in the injector rail harness lol. i didn't cuz that seemed like a very very dumb comment to make.
Old Feb 20, 2012 | 07:15 PM
  #35
martyg's Avatar
martyg
Didn't even think to look at that plug bc it is a silly mistake and I had that ruled out from the get go. I will say that the people from stillen did help out more then I thought they would from reading the forums. It ran for the time it was on, but now I have to swap the pump again and makesure everything still works. After I get everthing put back together I will post a video.
Old Feb 21, 2012 | 06:32 AM
  #36
Q8y_drifter's Avatar
Q8y_drifter
No check engine light?
Old Feb 21, 2012 | 08:54 AM
  #37
SharpByCoop's Avatar
SharpByCoop
Lightbulb
Originally Posted by SharpByCoop
In your case, you mucked with the injectors and the fuel pump.
My money says the tune is just fine, and it's mechanical or incorrect wiring.
I won't say I told you so. No I won't.
Excellent!
Coop
Old Feb 21, 2012 | 01:17 PM
  #38
martyg's Avatar
martyg
The kit is installed and all is working. I still have to go for a longer then 10mi drive. After I drive for a bit longer I will post more information. This kit isn't hard to put on, you just have to patience with it and not to forget the simple stuff.
Stillen Kit Installed and Working. - YouTube
Old Feb 21, 2012 | 01:19 PM
  #39
martyg's Avatar
martyg
I had a misfire one after I finally got it running, but cleared up after I made some adjustments.
Old Feb 21, 2012 | 01:41 PM
  #40
Weiboy718's Avatar
Weiboy718
Congrats! Welcome to the FI club!
Old Feb 21, 2012 | 03:55 PM
  #41
Staples's Avatar
Staples
Congrats on the install! If you're not running a Wideband, I'd recommend you take it easy to break the charger in and strap it to a Dyno to check where your air / fuel ratios are and to make sure there's no detonation. Better safe then sorry for long-term reliability!
Old Feb 21, 2012 | 04:01 PM
  #42
Congrats on being able to install it yourself, even with the hiccup. Let us know how it goes after it's tuned.
Old Feb 21, 2012 | 05:34 PM
  #43
Buckeye G's Avatar
Buckeye G
Congrats man. Id love to be able to slap on some FI.
Old Feb 22, 2012 | 09:20 PM
  #44
martyg's Avatar
martyg
Anyone know the name of the module that you can hookup to the nav screen?
Old Feb 22, 2012 | 09:37 PM
  #45
martyg's Avatar
martyg
Are "Hot Starts" normal for the Stillen tune? I have had two so far.
