Help Stillen Supercharger kit install HELP!
Old Feb 22, 2012 | 09:40 PM
  #46
Weiboy718's Avatar
Weiboy718
Originally Posted by martyg
Are "Hot Starts" normal for the Stillen tune? I have had two so far.
pretty normal!
FYI, get a full custom tune man! your car will love you for doing so!
Old Feb 22, 2012 | 09:44 PM
  #47
martyg's Avatar
martyg
I am next week, but that is pretty weird since the kit is 6k. Also does the Vortech blower have a ticking sound to it normally?
Old Feb 22, 2012 | 09:55 PM
  #48
Weiboy718's Avatar
Weiboy718
good and no it is not weird at all!
what does the ticking noise sound like? you checked the oil, belt, pulley or any loose bolts?
Old Feb 22, 2012 | 10:03 PM
  #49
martyg's Avatar
martyg
If you look at the video around 17 sec in you can hear it. I might be just hearing things.
Old Feb 22, 2012 | 10:05 PM
  #50
Weiboy718's Avatar
Weiboy718
nah, you not hearing things cuz i hear it too. its like ka ka ka ka ka ka ka
Old Feb 22, 2012 | 10:11 PM
  #51
martyg's Avatar
martyg
Right that is the sound, the blower belt is tight and the serpentine belt has an auto-tensioner. It sounds like a bad bearing or a loose bolt. I am going to keep an eye on it for now, but when I do the oil change I going to put a wrench on everything. I checked all the bolts by hand and none were loose.
Old Feb 22, 2012 | 10:21 PM
  #52
Weiboy718's Avatar
Weiboy718
you know! i heard that Vortech does not check their blowers before shipping them out.
Old Feb 22, 2012 | 10:24 PM
  #53
martyg's Avatar
martyg
Really because that would suck if the blower is bad. The oil if at the cross hairs mark therefore it should have the right amount of oil in it.
Old Feb 22, 2012 | 10:44 PM
  #54
Weiboy718's Avatar
Weiboy718
are you measuring boost level right now?
READ!
http://my350z.com/forum/forced-induc...questions.html
Old Feb 22, 2012 | 10:58 PM
  #55
martyg's Avatar
martyg
"the vortech can make a "broken sound" at idle. It normally makes a clunky, rattle where something just sounds broken on the car. To solve that, you might try increasing your idle rpms up to at least 900 rpms. Going to a smaller pulley also helps because they spin the blower faster, even while at idle. A dealer can increase the idle on earlier model cars. There's other ways too like ECU flashes, AAM's Cipher tool, some shops carry Consult II's which is what dealers use, some aftermarket engine managements can raise the idle. Some people have drilled a tiny 1/8 inch hole in their throttlebody which generally isn't recommended because it's permanent and an expensive part."
I have read this before and forgot the above note. When I get it tuned I will rasie the idle rpm. Do you know if they removed the speed limiter with the stillen tune because I was able to hit a speed that I thought wasn't possible in these cars.
Old Feb 23, 2012 | 06:22 PM
  #56
Buckeye G's Avatar
Buckeye G
Anyone know the name of the module that you can hookup to the nav screen?
HKS campII i belive. Wei has it.
Old Feb 23, 2012 | 07:06 PM
  #57
Weiboy718's Avatar
Weiboy718
Navtool.
2 aux inputs
No sound.
Only works for 08-09 models I believe.
Old Feb 23, 2012 | 07:31 PM
  #58
ANMVQ's Avatar
ANMVQ
Glad you got it started. Sounded exactly like mine did/.. I had hot starting issues too. The Stillen tune SUX , Huge time, Get your tune will fix everything, I have ZERO issues on my custom tune..
Yes my SC sounds like yours KLAK,KLAK,,
Old Feb 24, 2012 | 01:47 AM
  #59
martyg's Avatar
martyg
Navtool.
2 aux inputs
No sound.
Well that is no good then. Does anyone have any pictures of their gauge setup and/or recommendations for gauges?
Old Feb 24, 2012 | 02:04 AM
  #60
martyg's Avatar
martyg
This looks like it would work with the g37, but is their any A/V inputs in the 2011?
