Help Stillen Supercharger kit install HELP!
So it should be running all the time? if so I will take it apart and look. with the ACC only without starting it cuts out after a few seconds and when starting it goes on for a few seconds while trying to start. I did do the ecu reflash before trying to start. also before i even start the install i ran the car with the new pump for 5mins after the pump was replaced and it seemed to run just fine.
i hope your injectors are installed correctly too cuz that's gotta be a major pain to remove the manifold and surrounding parts.
keep us posted!
my muti-meter isn't working for me now. I check the wires for the MAF they are making good contact and is their a reason why their is a different number of wires for each MAF? Shouldn"t they have the same amount of inputs?
i believe you can use your stock pump to start up the car, just don't give any gas. try that out if you've exhausted your ideas
man! just my method and flash your car back to stock and try starting it. if it starts then it's likely your tune. i would do that first to eliminate the tuning issue first.
Watching the vid, it is definately a fuel problem. The car tries to run at :15" in the vid and then returns to starter RPM. That's a signal that a little bit of fuel sprayed and then stopped.
Tip: Take WD40 and spray it in an intake close to the throttle body for three seconds. Then try. If it does the same thing only a bit moreso, you've isolated the dilemma.
it may be a simple as a hose at the pump popping off. As a technician in my past career, retracing the steps and components I mucked with, always netted me the culprit. In your case, you mucked with the injectors and the fuel pump.
My money says the tune is just fine, and it's mechanical or incorrect wiring.
My ruling is the fuel pump as well. One way to possibly tell is to take off the fuel line where its going into the fuel rail(at the fuel damper). This is the same spot where you would install a fuel pressure guage line. Take this off. Dont start the car but have the line going into a bucket and see if when you put the car to on(NOT start) the fuel pump will prime and should spit out some fuel. This is another way to possible tell.
Take a look at the picture and see where the fuel line goes to the fuel damper. You will want to take the fuel damper off. Do not remove hose from damper. It will permantly damage fuel line. Also remove fuse to fuel pump and try to start car to remove pressure from fuel line. You can get to the damper without having to remove anything except the old engine cover which you can not use now that you have a stillen.
