Gas pedal - no response
Old Feb 13, 2023 | 02:21 PM
Axle94's Avatar
Axle94
Case updated
Originally Posted by BULL
Funny thing is I'm dealing with something similar.
Had a throttle code
P2101 Electronic Throttle Control Function
P1226 Closed throttle function
P1235 Closed throttle function
Did a throttle pedal dance, developed a
P010B Throttle -“Mass or Volume Air Flow “B” Circuit Range/Performance.
Changed MAFs due to one reading .20v off
Switched TBs, entered high idle, pedal dance gave me a smooth idle again however it still feels slow. Like many here I an extremely slow acceleration which goes away after 3500RPMs. From that point it revs up but not "tire breaking pull" like it should.
Have not driven it since, it does have broken flex pipes with a decent exhaust leak but after AF and O2 sensors.
i have changed the alternator today and it reads normally (14.2) and the problem persist
the gas pedal goes off suddenly and when i try to switch to Ds it still reads D ...Dtc show error of incorrect gear ratio and incorrect 5th gear ratio
Old Feb 13, 2023 | 03:12 PM
BULL's Avatar
BULL
Moderador
Your issue is transmission related. Almost 90% of the times you get an incorrect gear ratio code means the TCM located inside of the trasmission.
Old Feb 13, 2023 | 04:30 PM
Axle94's Avatar
Axle94
so man what do you think that i should look out to check ? Selonoids ? TCM? I’m from middle east not from USA and thx already for the help
Old Feb 14, 2023 | 08:11 AM
BULL's Avatar
BULL
Moderador
Your best bet is to look out for another transmission and swap the valve body to yours.
HarvirK
May 2, 2019 03:56 AM
Roman G
Apr 23, 2013 06:16 PM
G hits the spot
Apr 11, 2010 10:09 PM
Ivoidwarranties
General Tech Questions
Jan 24, 2009 10:46 PM
