over revving??
Old Nov 9, 2011 | 06:40 PM
FootLong's Avatar
FootLong
over revving??
I know you can over rev a 6-speed manual by downshifting into a lower gear. I also know that when doing this even the rev limiter cant help you. Is there any way possible to over rev the 7 speed auto? can you do the downshifting and rev matching to over rev? going from the manual back to "D" at higher rpm? I'm just curious, because I might have done such a feat!
Old Nov 9, 2011 | 08:36 PM
Itchytoe's Avatar
Itchytoe
It's an automatic transmission. Even when it's in manual mode, it's still an automatic transmission. It won't let you hurt it like that. Just get on the highway and click the down shift paddle a bunch of times. It'll drop to the lowest safe gear (probably third?) then basically tell you to go F yourself and stay in that gear till you slow down or tell it to shift up again.
Old Nov 9, 2011 | 09:32 PM
eksigned's Avatar
eksigned
yurp. it flashes at you and forces you to stay in the gear you're in. i over revved once in my 6mt. rev limiter helped! lol
Old Nov 9, 2011 | 10:35 PM
hobbs's Avatar
hobbs
I doubt you can over rev a auto by downshifting. Put a Saab rental car into reverse once at 70mph and nothing happened!
Old Nov 10, 2011 | 01:24 AM
Soliditude's Avatar
Soliditude
This. Love the explanation. Yeah, unless you're on a manual, it won't let you.
Old Nov 10, 2011 | 01:14 PM
ANMVQ's Avatar
ANMVQ
EH Ive bouched the REV limiter a few times the other day.. LOL was not paying attenion merging on the HW and was half a sleep,, 530am is early. BTW 7SPD Auto.
Old Nov 10, 2011 | 01:38 PM
ipitythefoo's Avatar
ipitythefoo
HAHHAAHAHHA holy crap. I want to try that.
Old Nov 10, 2011 | 08:44 PM
Itchytoe's Avatar
Itchytoe
It's very anticlimactic. You're driving down the road, and shift into reverse, and nothing happens. Your tranny says "F YOU!" and doesn't shift unless you slow down enough for it to do it without killing the engine.
Old Nov 10, 2011 | 09:15 PM
FootLong's Avatar
FootLong
Is it possible to have it In manual mode near redline and accidentally switch it to "d" rather than the next gear in manual mode (when the pedal is floored). I did that and I swear the tranny went ape ****e and flung to redline.....yes I'm a jabronie some times.
Old Nov 10, 2011 | 10:55 PM
Itchytoe's Avatar
Itchytoe
You certainly can switch it to d instead of telling it that you would like it to shift up a gear if that's ok with its programming. But alas, your tranny is smarter than you and still will not damage itself, or your engine. Rest assured, it's still ok
And because I've never seen anyone use these two smilies together, I'm going to
hooters
r0cketm0nkey
General Tech Questions
17
Nov 23, 2015 03:34 AM
DevilsG37s
12
Sep 12, 2015 05:01 PM
Badgerman
Aug 19, 2015 02:26 PM
