Help Transmission Issue!
Old Aug 7, 2011 | 05:27 PM
Bahrain5666's Avatar
Bahrain5666
Exclamation Transmission Issue!
Guys, I was driving my car few days ago, and everything was perfect for few minutes but there was a flare when it shifts from 3 to 4 gears. Reaching the traffic light I tried to accelerate, but what happened is that the car didn't respond! Tried again but the car didn't move, the gear shifted into neutral while the shift stick is still in D position! Had to shutdown the car and start it again and everything was ok! Few hours later same thing happens and I did the same thing, but this time I noticed that the radio channels whent back to the old setup! That means the ECU rested itself!
Anyone had the same issue or know about it?
2009 G37s 7AT
Old Aug 7, 2011 | 08:08 PM
advan37's Avatar
advan37
Check the transmission fluid level , it could be low.
Old Aug 8, 2011 | 02:28 AM
Soliditude's Avatar
Soliditude
ECU might be behind the problem. If it doesn't occur constantly, it sounds like there is a bug behind all the electronics. Take it to the dealer (if under warranty), and maybe they'll just reset it for ya and it'll be good. Either case, if it's warrantied, it's the dealer's problem.
Old Aug 8, 2011 | 05:11 AM
kool_yaar's Avatar
kool_yaar
^ whs, you have an 09 so you should not have problems getting it fixed under warranty, but you WILL have problems replicating the problem in front of the dealer, seems to be the case with me everytime...
i hope you are able to replicate it at the dealer so they can fix it, else make a video of your phone and that should be enough to have them actually try to fix it rather than giving it back to you few hours later saying "Could not replicate described problem"
Old Aug 8, 2011 | 11:44 AM
Bahrain5666
Thanks guys for your help, I will check with the dealer. The problem happened twice only, so Ill see how it goes and gonna update you all.
Old Aug 8, 2011 | 03:59 PM
Presto's Avatar
Presto
is the 7 a/t transmission serviceable? i thought it was sealed off
Old Aug 8, 2011 | 04:54 PM
Bahrain5666
Can you explain please?
Old Aug 8, 2011 | 05:53 PM
Frankyg37s's Avatar
Frankyg37s
good luck at your dealer,a while back u mentioned they are sucky and they only no the nissan tilda LOL
Old Aug 8, 2011 | 06:48 PM
Bahrain5666
Big time
Old Aug 9, 2011 | 08:07 AM
Al-Hammadi's Avatar
Al-Hammadi
Bahrain 5666 I totally agree with you the dealer is suck, they will try to run away from the problem stick to you complaint and don't collect the car without a full checking report from them.
Old Aug 9, 2011 | 11:30 PM
mw09g37's Avatar
mw09g37
main issue is that the TCM sits on the transmission itself... so you can't hack it without dropping ur tranny.. if that's what you're asking.
have to do it through the OBD>
redlinernyc
Feb 29, 2016 11:06 PM
mcgrible
21
Oct 27, 2015 07:14 PM
coachdave2001
Sep 21, 2015 12:05 AM
ZachThomas
Sep 3, 2015 01:40 PM
