7AT - fluid temp vs. line pressure?
Old Jun 7, 2011 | 08:39 PM
Q8y_drifter's Avatar
Q8y_drifter
Here's something I noticed while reading the Infiniti FSM. According to the text, the TCM raises the line pressure when the fluid temps is lower than "normal". Does that mean installing a big trans cooler will increase line pressure which speeds up shifting? Also, what temp. is considered "normal"?
Old Jun 12, 2011 | 06:59 AM
borfoo3's Avatar
borfoo3
I may be misunderstanding this, but doesn't that '5AT' on the top right imply that this might just be for the 5AT auto?
Old Jun 12, 2011 | 10:12 AM
Boomer-Bob's Avatar
Boomer-Bob
IMHO, line pressure is up to compensate for cold TF. Hot TF moves better in the lines.
Old Jun 12, 2011 | 05:01 PM
Q8y_drifter
I drive a 5AT G sedan so the FSM is differentiating between the 6MT and 5AT, rather than 5AT and 7AT. I'm assuming the same function is applied on the 7AT.
conkus805
ECU Tuning / Dyno Data
46
Nov 19, 2015 07:49 PM
rk325
Oct 13, 2015 01:51 PM
m3clubracer
Sep 28, 2015 03:45 PM
Allboutcali
Sep 26, 2015 03:43 PM
