Anyone Know What Temp Sends the VQ Into Limp Mode?
Old May 6, 2011 | 05:48 PM
PeTeToTe's Avatar
PeTeToTe
Like the title says, does anyone know at what oil temp we get sent to limp mode?
Old May 8, 2011 | 12:10 AM
mikelr's Avatar
mikelr
I would imagine it would be around the 220-240F range.
Old May 8, 2011 | 12:30 PM
mi135657's Avatar
mi135657
What do you mean "Limp mode"?. Are you refering to a loss of power in the lower rpms when the oil hits a certain temp?
Old May 8, 2011 | 02:54 PM
Adam West's Avatar
Adam West
When the car begins to overheat it will limit the engine to a certain amount of rpm to allow it to cool down the oil temps. I believe this condition only really exists during a road course track day in which you're often using WOT and eventually will start cooking the oil and raising the engine temps. Not sure if I've heard of it during drag strip runs or other spirited driving.
Old May 14, 2011 | 10:36 PM
paulg37's Avatar
paulg37
would anything else be causing this? I just had an oil change done, using amsoil. It just started out of the blue to studder at 2500rpm, it was a slow drive home needless to say... Oddly enough the VDC got disabled then the 'service engine soon' light came on 3/4s of the way back.
Old Aug 9, 2011 | 03:14 PM
keeweelee's Avatar
keeweelee
did you ever find out what was going on with your car?
Old Aug 9, 2011 | 09:27 PM
advan37's Avatar
advan37
I think its around 260-270F (130-135c) .
Old Aug 24, 2011 | 04:19 PM
terrycs's Avatar
terrycs
My oil temp hit 270 on the run between LA and Las Vegas this weekend. No limp, but it sure made me nervous.
Old Aug 28, 2011 | 02:50 AM
MiLK_MD's Avatar
MiLK_MD
What are your average operating temps and ambient temps?
Old Aug 29, 2011 | 02:37 AM
terrycs's Avatar
terrycs
I didn't chart the whole trip to get an average . I only have the peaks: oil = 270, water = 228, EGT (at the exhaust manifold) = 1457.
Ambient temp was between 96 - 106
Old Aug 29, 2011 | 08:59 PM
mikelr's Avatar
mikelr
Wow! I would be concerned too with oil temps that much higher than your water temp. Usually the oil comes in just below the water in temperature. I would invest in a cooler if I were you.
I don't run temp probes and such gear on my car... ignorance is truely bliss
Old Aug 29, 2011 | 11:45 PM
MiLK_MD's Avatar
MiLK_MD
Wow indeed. How fast were you going (RPM)? You must have been desperate to get to Vegas and made that run in less than four hours Vegas, baby, Vegas!
I miss that drive.
Oh also, may I ask, where are you measuring for temps? Are you measuring ECT and EGT directly or off the ECU? For the oil, off the block, sandwich plate, pan or elsewhere?
Italia311
Jun 28, 2016 11:25 PM
stm37s
The M - Spot
14
Oct 23, 2015 01:56 AM
stm37s
The M - Spot
Oct 1, 2015 06:53 AM
MrRiv
Sep 29, 2015 04:59 PM
m3clubracer
Sep 28, 2015 03:45 PM
