What's the current story with the 7AT???
Old Apr 30, 2011 | 06:07 PM
  #31
Warp37's Avatar
Warp37
Originally Posted by doug.nash
But, those lovely paddle shifters are THE saving grace for my car!!! Such a better way to stay in control of what the car is doing, and even in D, they temporarily take over. Just awesome.
Wha? They "temporarily" take over? Even in D? Paddle wasn't an option in my car (G37x) and in DS when using the shifter, once you use it, it does not revert to auto. But I think I read on the threads that one can install paddles even in an X. Is it true? And is it temporary even in D?
Old Apr 30, 2011 | 06:16 PM
  #32
Chris11LE's Avatar
Chris11LE
Yes, if you are in regular D the paddles will still upshift and downshift....after the revs settle down, it will revert back to regular D.
Interesting thing is that if you downshift and drive aggressively it keeps the car in manumatic longer than if you just downshift and drive normal.
I dont think anyone has been 100% positive that *all* cars can just have the paddles added, but I havent read of anyone that couldnt add them either.
Old Apr 30, 2011 | 06:21 PM
  #33
Chris11LE's Avatar
Chris11LE
I actually do see more than a few around LA. But that's to be expected. You see EVERYTHING around LA.
But that M56 is really a tough sell. It seems like it would be an amazing car (7AT aside) but it has strayed so far into the price index of the 5-series & E-series top cars. While it's still a little less than a loaded 550i - it just doesn't have the same feeling of value as the G does over the 3-series.
Agreed. The G is definitely the better value, the M is the "nicer" car. Another interesting point: I came from a 2001 i30 which *looks* bigger than the G, but the G had almost the same interior capacity (rear legroom was a little smaller). The M, I believe, is a bigger car than the i30. So, they never really made a direct replacement for the i, but the G comes close. The M also got some features that my old i had, and the G does not (power rear sunshade, etc)
I havent checked pricing on the M, but the only way Id consider one is if I could get an astounding deal on it....talking 45K or less for a loaded one (5K more than I paid for my G). Not even sure where that falls into place vs MSRP, but I might find out someday.....want to replace the wifes car in 3 yrs or so, might pick up an M at that point if they are still around.
Old Apr 30, 2011 | 08:12 PM
  #34
doug.nash's Avatar
doug.nash
The paddles in the "Sport" package are the coolest. In fact, that package has to be one of the most under-valued in history, considering all the cool upgrades. But being able to use the paddles to drop a gear or two, while still in normal "D" is awesome. While I still dislike the majority of the way the 7AT drives, those paddles go a loooong way towards making up for that.
Old Apr 30, 2011 | 08:17 PM
  #35
Boomer-Bob's Avatar
Boomer-Bob
For non-sport models, there is a thread in this forum on how to install sport paddles. They are plug and play in *most* late model G's. You probably do not have to even remove the steering wheel... Takes about an hour and about $250. (Infiniti of Riverside was selling them for about that price.) A no-brainer big bang for the bucks IMHO.
Old Apr 30, 2011 | 11:30 PM
  #36
devil2k's Avatar
devil2k
You don't, I just did mine. I taped everything with masking tape and I managed to put it in without scratching anything (or at least anything that I can see).
Old Apr 30, 2011 | 11:38 PM
  #37
gimpy's Avatar
gimpy
Originally Posted by JohnEnglish
I have an 09 G37xS that was part of the first delivery batch to North America. I've never had any issues and haven't done any transmission flashes.
I also have an 09 G37xS that I bought in Dec.09 and I guess I'm just lucky that there have been no problems. The 7 spd. trans has been great for me as far as how it shifts and responds to the amount of gas I feed it. It seems there are quite a few people with few if any problems with their trans but you don't here much from them, just the folks with problems. I can understand how mad you can get after spending 40+K for a car and having tranny problems that the factory can't seem to fix.
Old May 1, 2011 | 03:56 PM
  #38
CodeG's Avatar
CodeG
Paddles are not a must. I supposed people forgot that you can use the shifter to shift up and down gears.
Old May 1, 2011 | 04:00 PM
  #39
JohnEnglish's Avatar
JohnEnglish
I think their point is that to use the shifter to manuall change gear you need to put it into DS mode which will hold whatever gear you put it into. With the paddles you can leave the shifter in D and change gears and after a few seconds it reverts to fully automatic mode.
Old May 1, 2011 | 05:01 PM
  #40
Warp37's Avatar
Warp37
Even with after-market paddles? Anyone know?
Old May 1, 2011 | 08:24 PM
  #41
Chris11LE's Avatar
Chris11LE
AFAIK there are no "aftermarket" paddles. You order the paddle kit from an Infiniti parts dealer, using the Infiniti part number, so they are a genuine Infiniti (NOT aftermarket) part.
And I believe the paddle shifting in D is inherent to the programming of the manumatic mode, so it shouldnt matter if your car came with them or if you add them later, as long as the paddles function (i.e. the wiring is there), they should work exactly the same as a car that had them from the factory.
Old May 1, 2011 | 08:35 PM
  #42
TinsleyC's Avatar
TinsleyC
Expecting the car to respectfully downshift when you need a little more oomph is a lesson in futility. As you said, it's either limp along, or suffer through a three-gear downshift. But, those lovely paddle shifters are THE saving grace for my car!!! Such a better way to stay in control of what the car is doing, and even in D, they temporarily take over. Just awesome.
That's exactly why I added the paddles to my G. When I know I'm gonna need a boost of just give it a left-click and the power is there... well, two clicks if I'm going 45 in 7th, as one click from 7th puts you in 5th which is pretty slow at 45 MPH...
Old May 2, 2011 | 10:27 AM
  #43
djayash's Avatar
djayash
My 2011 G37X is 3000 miles old...I sometimes see the downshifting problems when I take the leg off the throttle to slow down from abt 35 mph....it limps to stop...Also, when accelerating from a full stop, the throttle response is pathetic....Even on a 2500 to 3000 rpm, it takes ages to get to 40 mph....Does the TSB fix these issues?
Old May 2, 2011 | 04:30 PM
  #44
Almatti's Avatar
Almatti
Originally Posted by devil2k
No I have not, the closest thing I've driven to a 335 is a 325. I've driven a variety of other cars, I4 / I4 turbo / small V6 / big V6 / regular ATX / DSG that shift smoother but they're mostly boring. The M35x 5AT I test drove even banged gear going from 2nd into 3rd.
No, I'm just saying once you flash it you lose that sportiness according to one of the thread floating around. That's the reason why I'm not getting mine reflashed. It doesn't shift into 7th in 20mph, I really hope that it does though.
It wasn't tweaked, I've driven my buddy's 2009 7AT G37x sedan and mine is just as jerky if not worse.
I'm just saying that your only options are:
1) Try some really good ATX fluid
2) Reflash it and lose the sportiness
3) Leave it the way it is
4) Trade it in for another car
5) Complain to Infiniti knowing that they won't do shxt about it
I have a Posted and Registered formal complaint with Infiniti of NA. Did that 2 months ago. Results: met still another time with the Service Manager of Pepe Infiniti, White Plains, NY. He is very diplomatic, very gracious and informative. They checked the car for proper operation, the diagostics came out fine: "It's working as it is designed to do"...The Manager took it for a test drive and gave it his personal attention. Pertaining to comment No. 5 from devil2k, Infiniti has responded to my complaints, and is continuing to follow up with me and the service manager, but I'm NOT expecting anything to miraculously change.
The Service Manager told me point blank, that is the way it is...Many have complained about it, BUT many customers have said nothing. For those of us that have driven the 07 G35X, like me, the 7AT has changed, in fact, it has Ruined this Car !!
Old May 2, 2011 | 04:32 PM
  #45
joepa's Avatar
joepa
'09 G37x with TSB applied. This was my wife's car that I'm now driving daily. The TSB fixed the harsh downshift, which I found unacceptable from Day 1. This from someone used to true manuals who likes to do a lot of downshifting. I still get the occasional 3-4 flare. Not sure if the TSB "neutered" the car, but overall the transmission still doesn't feel quite right to me.
My issue is the car's reluctance to downshift when at speed. I'm doing 25-30 mph, the speed limit goes to 55 when leaving town, I push down on the throttle and it won't downshift -- just slow acceleration at 1500-2k rpm -- unless I near floor it, in which case it drops two gears and rips. There's no middle ground!
+1. This is probably my single biggest complaint with this transmission. DS mode helps only slightly IMO. Manual mode I find is much better, power delivery is much more predictable.
Not sure about the paddle-shifter cars, but for my non-sport X, even in manual mode it kicks me down a gear (or several) if I slow down too much without downshifting. Normally not a big deal but try slowing down in 2nd gear...the auto downshift to 1st, in my car at least, can be quite harsh. I've driven several other "sport-shift" cars that did not do this.
Absolutely love this car though!
