Clutch replacement
Old Apr 16, 2011 | 12:09 AM
smitty8930's Avatar
smitty8930
Clutch replacement
So my clutch just went out on the freeway...how much does Infiniti charge to replace it at the dealership?
Old Apr 16, 2011 | 12:13 AM
Weiboy718's Avatar
Weiboy718
how do you know your clutch went out? is your clutch pedal dropped down to the floor? what is it doing?
Old Apr 16, 2011 | 12:18 AM
ricbel's Avatar
ricbel
I think clutches are supposed to gradually go bad like brake pads. Ive read of slave cylinders going bad. If your clutch pedal is just stuck to the floor, that may be your problem.
Old Apr 16, 2011 | 12:25 AM
Weiboy718's Avatar
Weiboy718
clutches doesn't usually don't just go bad unless you're always burning the flying crap outta it or doing some worthless launches imo. however they do wear out as time goes by.
OP: if your clutch pedal is stuck to the floor then you just became another victim of the notorious master slave cylinder and should be covered under manufacture warranty.
Old Apr 16, 2011 | 04:06 AM
Ken's Avatar
Ken
my dealer quoted me $1800 for a new clutch disc and $500 for install. if possible go with an independent shop and get an aftermarket setup.
Old Apr 16, 2011 | 07:45 PM
canucklehead's Avatar
canucklehead
^ lol, $1800 for a clutch disk is insane. do you mean flywheel & clutch disk and related parts? our cars have dual-mass flywheels which are very expensive so i could see $1800 for a full re & re, but no way for just the clutch disk.
Old Apr 16, 2011 | 07:49 PM
Weiboy718's Avatar
Weiboy718
he may be right! i remember asking my dealer how much does our flywheel cost they said roughly about 2k just for the flywheel hahaha.
Old Apr 16, 2011 | 08:07 PM
Tainui's Avatar
Tainui
No way I'd go to the dealership. Plenty of shops could install an aftermarket for half that including labor.
redlinernyc
Feb 29, 2016 11:06 PM
beng37s
Intake and Exhaust
Sep 19, 2015 01:32 PM
joshferbs
Sep 9, 2015 08:53 PM
inspector94
Sep 8, 2015 12:57 PM
ZachThomas
Sep 3, 2015 01:40 PM
