6MT Drivers: My 1-2 shift is very notchy!
Old Dec 21, 2010 | 11:53 PM
AUC2MIC's Avatar
AUC2MIC
I've noticed this happening more frequently now to the point where it happens almost every time. I shift out of first gear anywhere from 2.5k RPM to 3.5k RPM and whenever I do, I can feel that the shift isn't going through smoothly through my shifter. It's enough so that you can actually hear the gear going in with music off. I am sure I am pushing down on the clutch 100%. Does anyone else have this issue or is this something I should bring up at my next appointment?
Old Dec 22, 2010 | 12:14 AM
RaulGCustom's Avatar
RaulGCustom
SoCal Driven
No, mine still feels the same, I have 33k miles on mine.
Old Dec 22, 2010 | 01:07 AM
Obvis07's Avatar
Obvis07
have the problem too. its just hard to make it smooth on these cars
Old Dec 22, 2010 | 01:37 PM
cruzmisl's Avatar
cruzmisl
If you go higher in RPMs it'll be smooth.
There's a point where it feels smooth as butter. I think I get that kind of shift maybe 10% of the time.
Most of the time it feels notchy though.
Old Dec 22, 2010 | 01:54 PM
canucklehead's Avatar
canucklehead
if you get any grinding or resistance going into gear, take it to the dealer. you could be due a new tranny under warranty.
Old Dec 22, 2010 | 02:03 PM
ScottyBeGood's Avatar
ScottyBeGood
+1, Higher RPMS are the cure. I won't even shift the car less than 3k.
I agree there is a shift spot (1st to 2nd) that I get that feels like butter and the car just takes off, I get it about 5-10% of the time. Usually happens for me in tight traffic. damn.
Old Dec 22, 2010 | 02:21 PM
chilibowl's Avatar
chilibowl
Let the clutch up slow...Thats all that needs to be done..
Old Dec 22, 2010 | 03:37 PM
Mike's Avatar
Mike
Some questions.
1. How many miles on your current trans fluid? If you drive in a spirited manner, I'd recommend changing it more frequently. Fresh fluid makes the tranny feel GREAT.
2. Do you skip downshift?
3. Does this happen at any time on a 1-2 shift or only when the trans is cold?
Old Dec 22, 2010 | 04:15 PM
6mtg37s's Avatar
6mtg37s
Its normal with this tranny, they're rough and noisy.
Old Dec 22, 2010 | 04:23 PM
CEELOSG37S's Avatar
CEELOSG37S
LA G Club
I usually get it from 2nd to 3rd. But yea higher rpm equals smoother shifts.
Old Dec 22, 2010 | 09:01 PM
1cleanG's Avatar
1cleanG
NextLevel Performance
yep yep yep yep and YEP! there's plenty of threads on these forums about the tranny. I'll let it go without givin ya crap since you're a neeewb ;-) haha
Old Dec 23, 2010 | 03:02 AM
redrover23's Avatar
redrover23
I find that if, for the same shift point in terms of RPM...If I hit the gas harder to get there the notchiness subsides and it feels right going into all gears. If I ease into the gas, to that same shift point (at the lower gears 1->2, 2->3), I get the notchiness.
Old Dec 23, 2010 | 10:01 AM
123u's Avatar
123u
i found that at higher rev (3K-4K regular driving), it is much smoother...well i think it's telling us to drive it like it suppose to be driven....
Old Dec 23, 2010 | 11:00 PM
Frankyg37s's Avatar
Frankyg37s
i have the NICKEL MOD and shifts are SMOOOOOOTH.......TRY IT!!!!!!!!!
Old Dec 24, 2010 | 01:10 AM
Ken's Avatar
Ken
Sometimes I get this feeling of notchy shifting if I shift too fast and slam on the clutch pedal. It's most likely from the synchros not catching up to your shifting. A reason it probably feels less notchy when you rev higher is because you wait longer to let the rpms fall before shifting, giving your synchros time to sync up.
