Mixing 89 & 93 octane, will the tank blend them?
Old Nov 10, 2010 | 11:41 AM
  #76
SM_Shadowman's Avatar
SM_Shadowman
Originally Posted by iggs1
At low altitudes 89 should be just fine. 91+ is needed at higher elevations. That's all. Using low octane fuel such as 87 is asking for trouble in the longer run. Engine damage due to strong knocking may occur even with ignition retarding function. In addition, 87 octane fuel reduces performance which kinda defeats the idea of owning a performance car?
You have it backwards. At higher elevations there is less pressure, therefore the engine compression is naturally reduced and lower octane is needed. That's why gas stations in places like the Colorado Rockies offer as low as 85 and not much higher than 89.
At lower elevations there is more pressure and more compression, which requires higher octane.
Old Nov 10, 2010 | 06:56 PM
  #77
TinsleyC's Avatar
TinsleyC
Originally Posted by JohnEnglish
Several people are saying there's nothing wrong with putting 87 octane gas in a car requiring premium, the engine will just retard the timing. G37Sam is saying that it's silly to buy a sports car needing premium and then hamstring it by only buying regular gas.
I agree completely. Not only that, but I would hate to be in the position of not being able to afford 91.
Old Nov 12, 2010 | 01:50 PM
  #78
Patrick909's Avatar
Patrick909
Where I am, we only have the option to buy 87, 89, or 93. It does kind of annoy me to have to put in 93 when 91 is required, but what can you do. Around here there's barely any difference price-wise between 89 and 93.
Maybe when the tank gets 3/5 full I should top off with 89?
Here's a question - when you put in a higher octane gas than required, does that hamper performance at all?
Old Nov 12, 2010 | 02:26 PM
  #79
LightsOut's Avatar
LightsOut
It's 91 or higher ocatane
Old Nov 12, 2010 | 10:35 PM
  #80
SM_Shadowman
^^ what he said. It won't hurt, but also won't help.
Like you said, there's barely any price difference with the 89 and 91 so it's not worth tinkering to me, but I certainly don't fault the OP for trying.
Dillybar12
Engine, Intake and Exhaust
Nov 17, 2015 11:53 AM
jfisher
General Tech Questions
Nov 2, 2015 07:51 AM
2K1 6T8
Oct 6, 2015 07:40 PM
si_driver
ECU Tuning / Dyno Data
24
Sep 29, 2015 11:38 AM
Dillybar12
Sep 14, 2015 12:54 PM
