Help Just Ordered my 4.08 Final Drive
Old Oct 22, 2010 | 06:52 PM
  #46
kosstick's Avatar
kosstick
Originally Posted by Ivoidwarranties
I don't know what to tell you about the sedan's, I didn't ask any direct questions about them.
I did just get off the phone with Richard from Uprev and he says the wheel speed signal comes from the ABS control unit and he has no control over that at this time. They work solely with the ECU he says. But, I had to tell him that the manuals did not lose cc when changing gears and that was news to him, he thought they did.
So if you have an auto, no cruise control for you.
So basically I can get away with using the Quaife ATB Helical Dif and Final drive ring and pinion while using the stock housing?
Old Oct 22, 2010 | 07:46 PM
  #47
Ivoidwarranties's Avatar
Ivoidwarranties
Did your car come with the stock VLSD?
Old Oct 22, 2010 | 10:21 PM
  #48
kosstick's Avatar
kosstick
No idea lol. Never really got into that I have a sport premium navi 201 g37 coupe. I'm assuming I should
Old Oct 22, 2010 | 10:50 PM
  #49
Ivoidwarranties
If you have the Sport then it should have the LSD. Do you have the invoice or window sticker? It should have it on there.
Old Oct 22, 2010 | 11:46 PM
  #50
kosstick's Avatar
kosstick
It said I have viscous limited slip dif so I am good to go?
Old Oct 23, 2010 | 12:23 AM
  #51
Ivoidwarranties
Then yes. As far as I know, your stock housing and axle stub shafts would work with a Quaife differential and the 4.08 gears.
I still suggest you give someone like Z1 a call to double check and cover all your bases.
Old Oct 23, 2010 | 05:28 PM
  #52
kosstick's Avatar
kosstick
I will. I was just thinking would the 4.08 gears make my 1st n 2nd gear useless on a 7at. I'm assuming I'll just burn rubber. My rear tires are 265 I can't really go wider
Dillybar12
Oct 14, 2015 02:08 PM
Sway_NV
22
Aug 29, 2015 04:58 PM
Abramite
16
Aug 8, 2015 08:35 AM
