Help Gas pedal
Old Sep 22, 2010 | 11:07 PM
NeverBoneStock's Avatar
NeverBoneStock
Gas pedal
Trying to install my sprint booster and have no idea how to remove the gas pedal. Any ideas ? Thanx
Old Sep 23, 2010 | 02:09 AM
Dieseldoug22's Avatar
Dieseldoug22
Take out the floor mat. There is a plastic cover about 3/4" x 2" on the bottom part of the pedal. Looks as if it would cover two bolts to mount the assembly to the floor. Remove the cover piece. Remove 2 10mm bolts, then I think you slide the pedal assembly up the firewall an inch or 2. That will release a slide latch on the upper part of the pedal assembly, and it should be free now.
Old Sep 23, 2010 | 02:14 AM
NeverBoneStock
Figured it out..
linvbro
Aug 22, 2016 01:25 PM
MrRiv
Sep 29, 2015 04:59 PM
si_driver
ECU Tuning / Dyno Data
24
Sep 29, 2015 11:38 AM
r0cketm0nkey
Sep 27, 2015 01:34 PM
