Help engine not starting!!!
Old Aug 22, 2010 | 12:07 AM
GraphiteG37S's Avatar
GraphiteG37S
I'm not sure why your motor turned off but I would assume there's a fuse for the "push button start", I wonder if the fuse could be blown causing it not to restart? Or even if the starter on the car blew out?
Are you going to be contacting the dealer?
Old Aug 22, 2010 | 12:11 AM
Bahrain5666's Avatar
Bahrain5666
I will contact the dealer,,, for now my car is not starting for sure the battery is dead!! Even when I lock the door the horn is lowwwwww
So let's hope its just one dead battery!!
Old Aug 22, 2010 | 12:12 AM
Bahrain5666
What does the key sign with the word key on top stands for?
Old Aug 22, 2010 | 12:17 AM
GraphiteG37S
I think it mean to make sure that the key is inside the car. If the battery in the key fob is dead the car will not recognize that the key is in the car, therefore it will not start. Try plugging the key fob into the port in the dash below the steering wheel and attempt to start the car.
Old Aug 22, 2010 | 12:20 AM
Bahrain5666
That one I know about...
The one I'm talking about is a small key sign in black and yellow boarder..
Old Aug 22, 2010 | 12:36 AM
GraphiteG37S
Sorry I don't know that one.. Should be in the manual though.
Old Aug 22, 2010 | 12:50 AM
RYs06MT's Avatar
RYs06MT
just call roadside.. it's free. they will come check it out, and you will have the correct answer. if it's done they will tow it to the dealership. good luck.
Old Aug 22, 2010 | 04:45 AM
Bahg35's Avatar
Bahg35
I dunno why your engine has died on you all of a sudden. But b4 you take it to the dealer, make sure you put the stock parts back on. I dunn think they'll touch the car if its not stock.
Plus they'll blame the after market parts for anything!
Old Aug 22, 2010 | 09:53 AM
Fezzik's Avatar
Fezzik
They could but nothing he said should affect the engine, unless he got water into the car.
Old Aug 22, 2010 | 11:58 AM
xpimperx's Avatar
xpimperx
i'm sorry to hear man.
but a month ago, after parking my car for 10 mins, it wouldn't turn on any more. it would start and then bog down for 4 times (revs would stay very very low), then it wouldn't start any more. turned out to be a computer module in the car. it was replaced under warranty (costs about 300 BD). i don't have the exact name of the module, but it was something like EPDM.
i hope this is what's wrong at your side. good luck
Old Aug 22, 2010 | 02:18 PM
Q8y_drifter's Avatar
Q8y_drifter
Nissan / Infiniti Middle East regulations dictate that the warranty is automatically void if any modification is done to the car. This includes intake, cat back, hell even if you use synthetic oil.
Bahrain5666, remove ALL your mods and take it to the dealer. BTW, do you let the fuel tank almost run empty before you fill up?
Old Aug 22, 2010 | 02:30 PM
Bahrain5666
nope bro never let it run out
i just called the dealer earlier today, they now i have mods,,,,, he told me we kept the car on the computer and nothing was wrong with it..
they dont know why its not working!
he said " the car is cranking but it wont start " we will check it and inform you tomorrow..
Old Aug 23, 2010 | 02:13 AM
Bahg35's Avatar
Bahg35
Yea they're fine wen they know u have mods on the car .But wen it comes to warranty they'll ask u to remove em, or they'll blame u for the problem.
Hope you get everything sorted out soon, n hope its not a big issue!
keep us posted.
Old Aug 23, 2010 | 09:27 AM
  #29
Fezzik's Avatar
Fezzik
Sorry Didnt know this was in the middle east. I'm thinking north america.
Old Aug 27, 2010 | 09:07 PM
  #30
Bahrain5666
updates!
two days ago, the dealer called and said
" we were able to start the car, your ECU and engine are ok "
so i said then what was wrong
they said " the car had no spark so we had to check the (crankshaft sensor or camshaft sensor i cant cant remember which one ) have a problem so we removed it and made and indirect connection and the car started , so we need to check your flywheel to make sure where is the problem"
so ill pass by the dealer in few hours.. its 4 am here,,, so 4 more hors to go
so anyone have thoughts??
Amaadkhan2k
Oct 4, 2024 01:20 PM
reachout
General Tech Questions
38
Jun 27, 2020 12:35 AM
steven92
Sep 12, 2015 02:54 AM
SuicidalG37SGuy
Sep 10, 2015 06:01 AM
