Ticking feeling/sound on cold start
Old Aug 16, 2010 | 05:31 PM
owslystnly's Avatar
owslystnly
Firstly, this is not, as far as I can tell, coming from the engine.
Typically, after I reverse out of the garage and then proceed forward down the street, I end up feeling something "ticking". Feels like there's a HUGE rock or something in a tire. It is not transmitted through the wheel, more through my seat and/or pedals.
This feeling DOES vary with vehicle speed (not engine speed), and does occur with the clutch engaged or disengaged. Typically, after the car has warmed up, it goes away.
Any thoughts?
Old Aug 16, 2010 | 05:46 PM
BLKG37X's Avatar
BLKG37X
It's not inside the tire, but there's probably a small rock stuck in the thread of one of your tires. Every time you go over it, you hear it. The faster you drive the faster it ticks. Go through each tire until you find it.
No mustache rides for me thanks. To help is rewarding enough.
Old Aug 16, 2010 | 06:20 PM
owslystnly's Avatar
owslystnly
I thought it was a rock too.....but this sound goes away once the car warms up. Unless I lose and pickup a rock everytime i turn my car on/off
My car's name is moustache....
Old Aug 16, 2010 | 06:26 PM
Boomer-Bob's Avatar
Boomer-Bob
I'd go with BLKG37 and take a look see for rocks. It's cheap and might fix it.
If no rocks, see if someone can spot the wheel that is making the noise as you drive by. Could be a lot 'o stuff.
Old Aug 16, 2010 | 06:34 PM
owslystnly's Avatar
owslystnly
it was my initial assumption too.....but the fact that it vanishes, and happens quite frequently on cold starts, and then goes away....is odd. next time i hear it i'll check...again. need to take the car in for the navi/ipod tsb sometime soon, will prolly have the dealer take a look
Old Aug 17, 2010 | 12:42 PM
FatBoyG37S's Avatar
FatBoyG37S
Hey...did you happen to use valvoline synthetic oil on your car?
Old Aug 17, 2010 | 12:51 PM
owslystnly's Avatar
owslystnly
no. did my first oil change ~2000+ miles ago and used Pennzoil Platinum 5W-30. And I noticed this with the original Nissan Ester oil too.
Old Aug 17, 2010 | 09:09 PM
SpookyG's Avatar
SpookyG
I just started to have the same issue with my G. It sounds like the axle clicking I had on my previous g coupe.
Old Aug 18, 2010 | 12:03 AM
Boomer-Bob's Avatar
Boomer-Bob
Hmmm... have you tried backing up and repeatedly applying the breaks?
Long shot, but free.
Old Aug 18, 2010 | 10:08 AM
owslystnly's Avatar
owslystnly
brakes dude....brakes. and yes.
i'm used to repairing my car and keeping it in good running order. But i am also used to FWD and not such a tight suspension. Hence my trying to figure out if this is a large stone in the tire, or something else (I am leaning towards something else since whatever is happening imparts a "thunking" through the seat/pedals that I've not felt before when there is just a stone or nail in a tire)
But what would be present when things are cold and vanish when things warm up, I've no idea. All I could think of is a bearing, axle, driveshaft, differential, loose lugnut........but AFAIK, most of those things don't "warm up"
reachout
General Tech Questions
38
Jun 27, 2020 12:35 AM
Cmedlin96
Sep 20, 2015 11:09 PM
Raffay Khan
Intake and Exhaust
Sep 14, 2015 10:47 PM
luisalan
Sep 6, 2015 05:45 PM
